3750 switch reboot
Randy Willcox
I have a core switch and is stacked,  that has reboot at least 4 times I think it might be power supply related. Is there a debub command that can tell which switch in the stack is having issues.
Rajesh Hirani
Are all switches reloading?
I guess you can check the uptime of each switch which will tell you the faulty PS.
example:
Router#>sh ver | i switch <#>
True example:
Router#>sh ver | i switch 2
Here is a link to some cisco docs that might help:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swstack.html#wp1170763
