08-02-2005 08:56 PM - edited 03-03-2019 10:11 AM
hi all
will this 3750 switch support 2 no's of
10GB fibre uplink.
part no is
XENPACK-10GB-SR
Kindly post ur views.
binoy.
08-03-2005 03:40 AM
I assume you are connecting your 3750 GIG (1G) ports to 10G XENPACK Modules rite ? if this is the case i m sure that wont work out,coincidently today morning only i did something on the same line and found ports arent coming with proper patch cords.
i was connecting my 3750 to my 6513 box.
regds
08-03-2005 08:43 PM
Hi prem
i have a 3750 switch is it possible to put 2 10 gb XENPACK in this particular model.My core will be 6509-E
there also i will put 10 GB modules.
my concern is, will this 3750 support 2 no's of 10GB modules.
Thnaks & regds
Binoy.
08-03-2005 08:58 PM
hi
AFAIK 3750 dont take Xenpack modules it has provisioning for taking normal SFPs either may be ur LX or SX or ZX kinda models but again those SFPs supports 1G max and the XENPACK module is totally different in design altogether which cant be physically fit in 3750 (the slots which i have seen in 3750G are designed to take above mentioned SFP modules and not the XENPACK mod which u trying to put)
regds
