08-24-2011 05:51 AM - edited 03-04-2019 01:23 PM
I have a stack of five 3750X's connected in a single stack with the stackwise cables. Within this one stack, I created two power stacks, one power stack has 3 switches and the other has two switches. In each of the separate power stacks, one power stack port on a switch shows "shut", so the power stacks are not operating in a full ring. Is there a way to do a "no shut" no those stacks ports that are shut? IOS is 12.2(55)SE1 Here is the configuration -
stack-power stack XXX
stack-power stack YYY
stack-power switch 1
stack XXX
stack-power switch 2
stack XXX
stack-power switch 3
stack XXX
stack-power switch 4
stack YYY
stack-power switch 5
stack YYY
switch#show stack-power
Power stack name: XXX
Stack mode: Power sharing
Stack topology: Ring
Switch 1:
Power budget: 1663
Low port priority value: 22
High port priority value: 13
Switch priority value: 4
Port 1 status: Connected
Port 2 status: Connected
Neighbor on port 1: 6400.f1c3.5680
Neighbor on port 2: 6400.f1b9.b100
Switch 2:
Power budget: 1663
Low port priority value: 21
High port priority value: 12
Switch priority value: 3
Port 2 status: Not connected
Neighbor on port 1: 6400.f1c3.6100
Neighbor on port 2: 0000.0000.0000
Switch 3:
Power budget: 1663
Low port priority value: 20
High port priority value: 11
Switch priority value: 2
Port 2 status: Shut
Power stack name: YYY
Switch 4:
Power budget: 1663
Port 2 status: Shut
Neighbor on port 1: 6400.f1b9.b900
Switch 5:
Power budget: 1663
Neighbor on port 1: 6400.f1c4.e480
Solved! Go to Solution.
08-24-2011 01:45 PM
I don't really know why it is showing as shut, however, I know how you could do a shut/no shut on these ports.
config t
stack-power switch
standalone
no standalone
Hope this fixes it for you.
HTH,
Amit
08-24-2011 01:45 PM
config t
stack-power switch
standalone
no standalone
HTH,
Amit
08-25-2011 06:42 AM
That fixed it. The status of all power stack ports now show "connected". Thanks for your help, Amit.
