3825 Router problem
hardwarevnzla
Hello guys im having problems with the 3825 it doesn´t boot the ios
im getting this :
loadprog: error - Invalid image for platform
e_machine = 105, cpu_type = 145
boot: cannot load "flash:"
after checking the flash :
rommon 21 > dir flash:
program load complete, entry point: 0x8000f000, size: 0xcb40
Directory of flash:
2 33203200 -rw- c3745-adventerprisek9_ivs-mz.124-2.T5.bin
rommon 22 > boot flash:c3745-adventerprisek9_ivs-mz.124-2.T5.bin
boot: cannot load "flash:c3745-adventerprisek9_ivs-mz.124-2.T5.bin"
rommon 23 >
2 Accepted Solutions
ok thanks this router has 2 usb port can i copy the ios to one usb and then to the compac flash
It is possible if the ROMmon of the 3800 was upgraded, however, I don't believe this has been done.
How about ejecting the CF, find a multi-card reader and connect to a computer with USB.  And then copy the IOS from the computer to the CF.
which shold i copy
That's not my call.  It's your router.  It's your network.  Read the Release Notes and make that decision.
(However, if I was to choose among the three, I'd go for M9.)
also what are the procedures to install a new ios
As long as there is only one IOS in the CF then the router will boot the first valid IOS it will find.
10 Replies 10
hardwarevnzla
this is the complete information :
cisco System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Total memory size = 512 MB - DIMM0 = 512 MB, DIMM1 = 0 MB
c3825 platform with 524288 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
Upgrade ROMMON initialized
Directory of flash:
rommon 23 >
The image you are trying to boot from is not compatible with your hardware.
ok what ios version do you recommend for my router
The router is a 3825 but someone is forcing the router to boot an IOS for a 3745.  But the CF doesn't have the old IOS for the 3825, the router then boots into ROMmon.
ok thanks this router has 2 usb port can i copy the ios to one usb and then to the compac flash ?. what do you recommend...
ok i did that...deleted the c3745 ios from CF..now im going to copy a  new compatible ios but which should i copy ( i have access to this ios  ) :
c3825-adventerprisek9-mz.151-4.M9
c3825-adventerprisek9-mz.151-4.M5
c3825-adventerprisek9-mz.151-4.M3
... also what are the procedures to install a new ios...( boot statements ?,Save configuration changes ?.) thanks
which shold i copy
thanks bro the router is now working without problems...
Happy to hear it's finally working.
