3845 memory utilization increases
Cisco 3845 router (256RAM / 64Flash), increases the cpu utilization upto 70~80 percent, during the time of high utilization, I am unable to run show command on router.
The configuration is simple, this is connected with two internet links (24Mbps and 8Mbps) and its about 600~700 users are using internet.
show version, show memory and show process cpu outputs are attached here.
Kindly advise.
2 Accepted Solutions
%% Low on memory; try again later
This is very typical of a memory leak bug.  You will need to upgrade the IOS or reboot your appliance if you are unwilling to do so.
Can you recommend any updated IOS which will not show such error again.
Before you download the IOS of your choice, read the Release Notes.
7 Replies 7
Router is getting errors on console:
*Jun  1 08:25:02.871: %SYS-2-MALLOCFAIL: Memory allocation of 2000 bytes failed from 0x6018AFA0, alignment 8
Pool: Processor  Free: 101600  Cause: Memory fragmentation Alternate Pool: None  Free: 0  Cause: No Alternate pool
 -Process= "Chunk Manager", ipl= 3, pid= 1,  -Traceback= 0x618EF478 0x60165194 0x6016A868 0x6018AFA8 0x6018A000 0x60189DE4
*Jun  1 08:25:02.871: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for NAT Fragment0 . No memory available -Process= "Chunk Manager",
ipl= 3, pid= 1,-Traceback= 0x618EF478 0x60189E28
*Jun  1 08:25:04.107: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/0: the fragment table has reached its maximum threshold 16
Thank you for reply,
thanks a lot dear friend !!!
Thanks for the ratings.
HI,
I hv a question, can we limit NAT connection per user basis on IOS router?
Aman
