01-25-2007 06:20 PM - edited 03-03-2019 03:30 PM
We have a 3845 router that I have been tasked with setting up to replace our 2600 and VG200. The problem I am running into is that our WIC-1DSU-T1 cards are not recognized by the 3845. I have IOS version 12.4(11)T loaded on the 3845. when I do a show diag i get:
WIC Slot 1:
FT1 BT8360
WIC module not supported/disabled in this slot
Hardware revision 1.5 Board revision G0
Serial number 31589541 Part number 800-03279-04
FRU Part Number WIC-1DSU-T1=
I can't find documentation anywhere that says for sure that this card is not supported in the 3845. Has anyone got this to work? I don't want to upgrade to the v2 version of the card unless i have to. Thanks in advance.
Bill
01-26-2007 02:54 AM
Hi Bill
Can you post the output of show version here ?
regds
01-26-2007 02:57 AM
Hi Bill
Unfortunately, you need V2 version for 3800 routers. See below:
Hope this helps
