11-25-2014 01:27 PM - edited 03-05-2019 12:14 AM
I have a 3925 with 4 Gig Integrated Interfaces and 2 SFP GI0/0 and GI0/1. Will I be able to use the SFP interfaces if the integrated GI0/0 and GI0/1 are being used?
Thanks.
Todd
11-25-2014 02:17 PM
Todd,
I believe those interfaces are either/or meaning that you can use either rj-45 or an sfp, but not both for the same port.
HTH,
John
11-25-2014 03:46 PM
Hello
If you mean connecting sfp copper GB module to a integrated copper GB port then yes you can.
res
Paul
11-25-2014 06:09 PM
I do agree with John, you would not be able to use both on the same module at the same time.
Aref
