3925 Web Access
Michael Durham
Level 4
Level 4
I have a C3925 router and its working fine.  I try to go to its webpage at 192.168.69.1 and I get a blank screen no matter which browser I use.  I know there should be a limited page that I should see.
I do have CME GUI installed on the router and when I go to 192.168.69.1/ccme.html, I get the CMEGUI.
How can I also get the router's GUI?  What files am I missing?
10 Replies 10
Hello
Have you enabled http/https access for the router?
sh ver
dir flash:
sh run | sec http
Kind Regards
Paul
TDC_CME_Router#sh ver
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.7(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 01-Aug-18 23:07 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
TDC_CME_Router uptime is 4 weeks, 3 days, 22 hours, 24 minutes
System restarted at 22:53:31 EST Tue Dec 3 2019
System image file is "flash0:c3900-universalk9-mz.SPA.157-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE100/K9 with 991232K/57344K bytes of memory.
Processor board ID FTX10000057
4 Gigabit Ethernet interfaces
3 terminal lines
1 Virtual Private Network (VPN) Module
1 cisco Integrated Service Engine(s)
Cisco WLAN Controller 4.2.205.0 in slot/sub-slot 1/0
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
Cisco Unity Express 8.6.9 in slot/sub-slot 0/0
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
511056K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 C3900-SPE100/K9 FOC000002C
Suite License Information for Module:'c3900'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c3900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
TDC_CME_Router#dir
Directory of flash0:/
1 drw- 0 Dec 20 2018 19:53:50 -05:00 html
29 drw- 0 Dec 20 2018 19:55:42 -05:00 cpexpress
60 drw- 0 Mar 28 2019 20:38:02 -04:00 CME_GUI
83 drw- 0 Dec 20 2018 07:46:54 -05:00 PhoneFiles
169 -rw- 1038 Aug 26 2010 20:53:08 -04:00 home.shtml
170 -rw- 115712 Aug 26 2010 20:53:16 -04:00 HOME.TAR
171 -rw- 1697952 Aug 26 2010 20:53:30 -04:00 securedesktop-ios-3.1.1.45-k9.pkg
172 -rw- 415956 Aug 26 2010 20:53:42 -04:00 sslclient-win-1.1.4.176.pkg
173 drw- 0 Feb 13 2019 18:27:14 -05:00 firmware
175 -rw- 31990 Mar 4 2019 15:22:36 -05:00 backup-confg
176 -rw- 2903 Aug 26 2010 20:52:48 -04:00 cpconfig-39xx.cfg
177 -rw- 2915328 Aug 26 2010 20:53:00 -04:00 cpexpress.tar
178 -rw- 1160 Feb 27 2013 12:23:56 -05:00 FOC1433282C_201302201237484020.lic
179 drw- 0 Jan 30 2019 17:05:52 -05:00 Desktops
210 -rw- 831488 Mar 28 2019 20:37:02 -04:00 cme-gui-9.0.0.0.tar
211 drw- 0 Oct 3 2019 16:55:22 -04:00 its
220 drw- 0 Dec 20 2019 12:59:58 -05:00 Audio
218 -rw- 115471144 Sep 13 2019 13:34:48 -04:00 c3900-universalk9-mz.SPA.157-3.M3.bin
219 -rw- 88886368 Feb 13 2019 19:47:40 -05:00 c3900-universalk9-mz.SPA.152-4.M1.bin.old
222 -rw- 830464 Jan 4 2020 17:32:56 -05:00 cme_Files
522969088 bytes total (145448960 bytes free)
TDC_CME_Router#sh run | sec http
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:CME_GUI
url services http://w1.weather.gov/xml/current_obs/KLCQ.xml
TDC_CME_Router#
Hello
have you tried connecting via https:// x.x.x.x  as well as http://x.x.x.x
Kind Regards
Paul
neither http:\\192.168.69.1 or https:\\192.168.69.61 work
I even reset the ip http path to just flash: and still not working.
https://192.168.69.1/archive/archive:home/html/home_aux.shtml
404 Not Found
Now that the web root is configured for CCME I don't believe you'll be able to get to anything else.  Console/ssh are your friend now.
On a 2801 router, I was able to get to both the router's gui page and the ccme page.  I think the html files are missing for the router itself.
How were you able to get both gui working, please?
looking at the output you have posted:
it looks like you are running CME version 9.0. The compatibility matrix (linked below) recommends version 12.0, you might want to try and load these files and check if that makes a difference...
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
No, that file is just a backup of the 9.0 gui files I used to have on the router.  I am using the correct 12.0 CME GUI files and they ARE working correctly.  Just NO router html files are working.
I found out a little more.
When I go to http://192.168.69.243/level/15 I see this page:
But, when I go to http://192.168.69.243/level/15/exec/- I now see this:
and when I go to this url http://192.168.69.243/level/15/exec/-/configure/http I see:
All of the command work too.  Its just that the home page is missing/not working and would like to get it working too.
