3945 Nat problem
Lau Chun Yin
Hi Expert,
Does 3945 support nat for SCTP ?????
Reza Sharifi
Thanks for the reply.
By the way, i'm doing the NAT on my 3945 router
ip access-list extended test
permit ip host 192.168.25.29 host 203.203.203.203
deny   ip any any
ip nat inside source static 192.168.25.29 202.61.61.61 route-map test
The Layer 4 protocol should be SCTP, it seems the NAT translation is fail....
does anyone know CISCO NAT support SCTP or not ?
hi,
i don't see any match and set clauses for your route map. could you post your 3945 config? Try to do as below and post the show ip nat translation | i 192.168.25.29 output as well.
int
ip nat out
int
ip nat in
