4331 Webui will not work without HTTP
Hello all,
after a long search I finally had HTTPS working on a 4331 (IOS-XE 16.6.1) (with a selfsigned certificate) but if I disable HTTP, the webinterface stops working.
Chrome shows:
Firefox shows:
With enabling the HTTP server all works well gain.
Why make it so hard just to enable a webinterface ? IOS 15 could do it in a simple way, so why make it so hard on IOS-XE ?
With kind regards,
Marcel Tempelman.
Hello Marcel,
you are probably hitting the bug below:
CSCuz57866
Description
Symptom:
When trying to access the WebUI on port 443 with "no ip http server" configured you will not get any response from WebUI
Conditions:
When trying to run HTTPS without "ip http server" configured
Workaround:
Configure "ip http server" along with "ip http secure-server"
Known Fixed Releases: (10)
Everest-16.6.2
Denali-16.3.5
16.6.2
16.3.5
16.3.5b
Denali-16.3.5b
16.7(0.149)
16.3(4.108)
Hello Georg,
thank you for your reply. I'm going to check this with an update.
With kind regards,
Marcel Tempelman.
