ā02-02-2023 05:51 AM - edited ā02-02-2023 05:54 AM
Hello.
On a 4431 router, how to config an extended ACL for a range of TCP ports 2200-2300?
Thank you.
Solved! Go to Solution.
ā02-02-2023 06:45 AM
ā02-02-2023 06:21 AM - last edited on ā02-05-2023 10:50 PM by Translator
not sure full context - if you looking only syntax - how about use as below :
(config)# object-group service service_group
(config-service-group)# tcp range 2200-2300
ā02-02-2023 06:35 AM
OK. and what is the syntax to insert this into an ACL?
instead of using eq in ACL use range.
that it.
ā02-02-2023 07:10 AM
refer this syntax :
