I need to factory default a pair of 4500 switches in VSS mode.
This is how I plan to do it.
1. on switch 1 execute redundancy force-switchover
2. write erase on the switch 2 and reload
3. this should failover to switch 1
4. write erase in switch 1
Is there anything I missed? Should I remove
Maybe I should do a switch convert mode stand-alone on both switches and then do a write erase on both?
