4500X with 1G SFP
garry cordess
With a 4500X 32 port we are seeing that when a 1G SFP like a GLC-T or a GLC-SX-MM is plugged in it shows up as a 10G SFP.
Is there a problem here or is that normal?
Garry. C.
jj27
If you do a show inventory does it truly show up as a 10GB SFP, or are you just concerned because the interfaces show up as TenGigabitEthernet even though it's populated with a 1GB SFP? If the latter, no worries as it is by design.
