08-01-2005 09:42 AM - edited 03-03-2019 10:10 AM
Trying to setup a 4510. Having problems with VLAN 1 not coming up. VLAN 1 shows down - down. No shut command is not working. HELP!!!
08-01-2005 11:26 AM
Do you have at least one port in VLAN 1 with an active device plugged into that port? Without at least one active device the VLAN will not come up.
Rick
08-01-2005 11:56 AM
Hi Aj,
As stated in pevious post you need to have atleast one port assigned to vlan 1 to make it active. But even if you configure any port as a trunk port it will bring your vlan 1 as up.
Try that and update us.
Ankur
08-02-2005 10:28 AM
Configure one port as a trunk.
regards...
Ashish Singh
08-02-2005 03:43 PM
Your SUP engine (whether 3, 4 or 5) has layer 3 capabilities on it. No matter what you do with a "no shut", under the vlan interface...you will not see it up/up until atleast on client is connected to any of the ports that fall under vlan 1. So connect a laptop or a PC to one of the ports, put that port into vlan 1 and you should see Vlan 1 status up/up. You can also verify this by executing a show ip route on the switch.
08-02-2005 05:07 PM
Cool... Problem is solved.
08-02-2005 08:20 PM
Can u post.... wat was the solution ?
regards...
Ashsih Singh
