02-21-2017 12:47 AM - edited 03-05-2019 08:04 AM
I have configured a Cisco 2900 router to support the 4G and I configured a tunnel but the 4G WIC is turning down and on repeatedly!
02-21-2017 06:29 PM
What model card do you have ("show inventory" will tell you the answer)?
02-21-2017 09:55 PM
please share the following command
sh cell 0/2/0 all
02-21-2017 11:45 PM
sh cell 0/2/0 all
Hardware Information
Modem Firmware Version =
Modem Firmware built =
Hardware Version =
Device Model ID:
Package Identifier ID:
International Mobile Subscriber Identity (IMSI) =
International Mobile Equipment Identity (IMEI) =
Integrated Circuit Card ID (ICCID) =
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Modem Status = Offline
Current Modem Temperature = 0 deg C
PRI SKU ID = 1102029, PRI version = 005.026, Carrier =
OEM PRI version =
Profile Information
Profile password Encryption level: 7
* - Default profile
** - LTE attach profile
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current System Time = None None 0 0:0:0 0
Current Service Status = Normal
Current Service = Circuit Switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network =
Mobile Country Code (MCC) = 0
Mobile Network Code (MNC) = 0
Packet switch domain(PS) state = Unknown/Not Applicable
Cell ID = 0
Radio Information
Radio power mode = online
Channel Number = 0
Current Band = Unknown
Current RSSI = -0 dBm
Current ECIO = -0 dBm
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = AUTO
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 0
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS Status: GPS mode or nmea not enabled
SMS Information
SMS Service is not available
Number of outgoing SMS pending = 0
Error Information
This command is not supported on this platform.
Modem Crashdump Information
WIC type is BC7
Cellular0/2/0 is MC73xx based
Modem crashdump logging: off
02-21-2017 11:51 PM
Could you share your dialer string?
Have you tried power cycling the router?
02-22-2017 12:08 AM
would you tell me please how can I get the dialer string?
and yes I have tried.
02-22-2017 12:10 AM
Your config references "hspa-R7" so look for a script with that name in the running config. Can you also show your "line" config.
02-26-2017 12:17 AM
would that help?
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 0 CTY - - - - - 0 0 0/0 -
1 1 AUX 9600/9600 - - - - - 0 0 0/0 -
2 2 TTY 9600/9600 - - - - - 0 0 0/0 -
* 0/2/0 35 TTY - - - - - 0 0 0/0 Ce0/2/0
0/2/1 36 TTY - - - - - 0 0 0/0 Ce0/2/1
388 388 VTY - - - - - 0 0 0/0 -
389 389 VTY - - - - - 0 0 0/0 -
390 390 VTY - - - - - 0 0 0/0 -
391 391 VTY - - - - - 0 0 0/0 -
392 392 VTY - - - - - 0 0 0/0 -
393 393 VTY - - - - - 0 0 0/0 -
394 394 VTY - - - - - 0 0 0/0 -
395 395 VTY - - - - - 0 0 0/0 -
396 396 VTY - - - - - 0 0 0/0 -
397 397 VTY - - - - - 0 0 0/0 -
398 398 VTY - - - - - 0 0 0/0 -
399 399 VTY - - - - - 0 0 0/0 -
400 400 VTY - - - -
000101: *Feb 26 10:11:44.031 UTC: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/2 is now UP - 0 0 0/0 -
401 401 VTY - - - - - 0 0 0/0 -
402 402 VTY - - - - - 0 0 0/0 -
403 403 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
3-34, 37-387
interface Cellular0/2/0
no
no
no
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string
dialer string gsm
dialer string hspa-R7
dialer-group 1
async mode interactive
end
02-26-2017 11:03 AM
No. I want to see the bit of your config beginning with "line ...".
02-21-2017 11:44 PM
NAME: "4G WWAN EHWIC - Global Multimode(Europe) LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS on Slot 0 SubSlot 2", DESCR: "4G WWAN EHWIC - Global Multimode(Europe) LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS"
PID: EHWIC-4G-LTE-GB , VID: V01 , SN: FOC20360UK2
NAME: "Modem 0 on Cellular0/2/0", DESCR: "Sierra Wireless MC7304 4G-GB"
PID: MC7304 4G-GB , VID: 1.0, SN: 352761061531506
