4G router configuration
Hi huys,
I'm truing to get 4G communication working on my router, but it doesn't work.
Is there any specific config related to the country (in this case belgium, proximus provider)?
Below the output sh cell 0 all
Although the LTE preference setting is set to automatic, the selected one is unknown...
LTE Technology Selected = UNKNOWN
any idea?
login as: tech
Using keyboard-interactive authentication.
Password:
SECBXRT207#sh cell 0 all
Hardware Information
Modem Firmware Version = SWI9200X_03.05.19.04
Modem Firmware built = 2012/09/17 17:57:14
Hardware Version = 10
International Mobile Subscriber Identity (IMSI) = 20612900080056
International Mobile Equipment Identity (IMEI) = 359470040169882
Integrated Circuit Card ID (ICCID) = 8932002100184388397
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) = SWI9200X_03.
Profile Information
Profile password Encryption level: 7
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = 178.145.80.106
Access Point Name (APN) = internet.proximus.be
Authentication = Unknown
Username:
Password: 00
        Primary DNS address = 80.201.237.238
        Secondary DNS address = 80.201.237.239
 * - Default profile
Data Connection Information
Data Transmitted = 2226395058 bytes, Received = 151800471 bytes
Profile 1, Packet Session Status = ACTIVE
        IP address = 178.145.80.106
Profile 2, Packet Session Status = INACTIVE
        Inactivity Reason = Unknown
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Mobile Country Code (MCC) = 206
Mobile Network Code (MNC) = 1
Packet switch domain(PS) state = Attached
Registration(EMM) state = Registered
Radio Information
Radio power mode = ON
Current RSSI = -63 dBm
LTE Technology Preference = AUTO
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
Error Information
This command is not supported on 4G modems.
Modem Crashdump Information
Modem crashdump logging: off
SECBXRT207#
Dan Lukes
Wrong community, moreover, you mentioned no product you are speaking of (I assume EHWIC-4G-LTE-G). Thus no answer so far ...
See CSCug43453
It may or may not be related.
Please check your routing part & add #show ip interface brief & #show ip route outputs.
For more investigation, please use below debug command too.
#debug chat
#debug async state
#debug dialer
#debug modem
From your output (#show cellular 0 all), APN profile, signal, ip address negotiation everything is working fine. So kindly check your routing part & share the output.
Bye, Have a nice day.
