64 bit interface?
Ricky S
Level 3
Level 3
Hi everyone, I am configuring an NMS software (Zenoss) to work with my Cisco devices. In Zenoss there is an option to set alerting for 32-bit or 64-bit ethernet interfaces. Would Cisco interfaces be considered 32-bit or 64-bit?
darren.g
Level 5
Level 5
It depends on the speed of the interface, not the type of device.
SNMP version 1 supports only 32 bit counters - which means that for 1 gig (or faster) interfaces, you don't get a "true" indication of utilisation or speed.
If your device only supports SNMP version 1, then it's a 32 bit device as far as your NMS software is concerned. if your device supports (and has enabled) SNMP v2 or SNMP v3, then it's a 64 bit device as far as your NMS is concerned.
Most Cisco modern Cisco devices support SNMP v1/2c/3, so they're all "64 bit" devices, provided you have enabled the appropriate level of SNMP on your device.
Cheers.
5 Replies 5
Andrew Zizzo
I'm not familiar with the software, but you can see what processor your appliance is equipped with by running show version
For example, on a 2950 switch, midway through the show version would read:
"cisco WS-C2950-24 (RC32300) processor (revision R0) with 21039K bytes of memory."
A quick search shows that the RC32300 is a 32 bit processor. In fact, the 32 after RC designated 32 bit archeticture and the 64 bit family is named RC64xxx
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Is the question 32 or 64 bit SNMP MIB counters?
darren.g
Level 5
Level 5
Cheers.
Thanks for your input everyone.
Thanks Darren, thats exactly what I needed. Yes my router does have snmp v2c enabled.
Cheers!
Cheers!
No worries, glad to have helped.
