Join Customer Connection to register!
600
CiscoGirl
Beginner
6500 Core (no VSS) to Nexus 5500 with vPC, L3, Routing, HSRP & OSPF
Hi, I have 2 6506 Core Switches running HSRP (no VSS) and Nexus 5596-UP connected to it at L2. Just like this setup I followed and it works.
https://community.cisco.com/t5/switching/vpc-on-nexus-5000-with-catalyst-6500-no-vss/td-p/1618853
Now we want to move a few congested vlans (vlan701 & 704) from the 6506 to the 5596-UP (add routing and ospf to the Nexus because 6506 can only handle 1G per vlan with the current hardware and the 5596-UP have 10G... and I can only work with the current hardware).
1. OSPF is configured on the 6506-CORE1 and 6506-CORE2 and works. I want to move vlan from core1, add routing and ospf to the Nexus. See the "<<<add" in the config. Does the 5596-UP ospf config look right or do I need to add something to it? Any suggestions on OSPF?
2. How would I configure the the uplink from Nexus 5596-UP to 6506 Core, leave it as a L2 is ok?
6506-CORE1#
router ospf 1
redistribute connected subnets
redistribute static subnets
passive-interface Loopback0
network 10.0.20.177 0.0.0.0 area 0.0.0.0
network 10.0.0.0 0.255.255.255 area 0.0.0.0
default-information originate
N5K-1#
feature ospf
feature pbr
feature interface-vlan
feature hsrp
feature lacp
feature dhcp
feature vpc
feature lldp
feature vtp
interface Vlan550
no shutdown
vrf member VPC-KEEPALIVE
ip address 10.10.50.2/24
vpc domain 5
role priority 10
peer-keepalive destination 10.10.50.3 source 10.10.50.2 vrf VPC-KEEPALIVE
delay restore 150
auto-recovery reload-delay 300
interface Ethernet1/5
description KEEPALIVE - N5K1 TO N5K2
switchport access vlan 550
interface port-channel50
description 5K1 TO 5K2
switchport mode trunk
spanning-tree port type network
vpc peer-link
interface Ethernet1/9
description PEER-LINK
channel-group 50 mode active
interface Ethernet1/10
interface port-channel61
description TO 6506-CORE1
vpc 61
interface port-channel62
description TO 6506-CORE2
vpc 62
interface range Ethernet1/1 - 4
description ETHERCHANNEL (4) TO 6506-CORE1
channel-group 61 mode passive
interface range Ethernet1/45 - 48
description ETHERCHANNEL (4) TO 6506-CORE2
channel-group 62 mode passive
interface Vlan701
 description SYSTEMS_01
 no shutdown
 no ip redirects
 ip address 10.10.0.2/24 <<<add
 ip router ospf 1 area 0.0.0.0 <<<add
 hsrp 1 <<<add
  preempt
  priority 120
  ip 10.10.0.1
interface Vlan704
 description SYSTEMS_03
 no shutdown
 no ip redirects
 ip address 10.10.16.2/24 <<<add
 hsrp 1 <<<add
  preempt
  priority 120
  ip 10.10.16.1
interface Vlan751
 description HW3-CISCO-MGT
 no shutdown
 no ip redirects
 ip address 10.10.7.32/24
interface loopback0
 ip address 10.0.21.1/28
ip route 0.0.0.0/0 10.10.0.1
router ospf 1 <<<add
 area 0.0.0.0 range 10.10.0.0/22 <<<add
 area 0.0.0.0 range 10.10.16.0/24 <<<add
 area 0.0.0.0 range 10.0.21.0/28 <<<add
1 ACCEPTED SOLUTION
CiscoGirl
Beginner
2018SEP18 - I implemented this over the weekend and it works with the below tweaks!
  1. Moving vlan 701 and 704 off the Core to the Nexus 5596 to elevate 1G vlan on core to nexus 10G vlans.
  2. Nexus - using L3, OSPF & PBR
  3. I left the trunk ports from core to nexus as L2.
  4. I’m not an architect or good with RP, but this is what I have and it works! I added in some other commands to configure Nexus also.  Any suggestion is welcome.
Lesson Learned / Info:
  1. Create another vlan on Core and Nexus for routing between the N5K and CORE, (vlan 552, ip route 0.0.0.0/0 10.8.52.1)
  2. Nexus 5596 doesn’t support Netflow, so you can’t see Netflow if you move the vlan to Nexus. Newer model support Netflow.
  3. Route-map doesn’t support deny.
N5K-1 (config-if)# ip policy route-map TO_LA_ENLAN
% Could not apply PBR route-map - policy action not supported
2018 Aug 16 13:02:15 HW3-N5K1-SW1 %$ VDC-1 %$ %RPM-2-PPF_SES_VERIFY:  rpm [4172]  PPF session verify failed in client afm(Line card  1/VDC  NONE/UUID  656) with an error 0x41ee0013(policy action not supported)
6506-CORE1#  (CORE2 WOULD BE SIMILAR WITH DIFFERENT IP)
router ospf 1
!I would do more specific network below, but it is before me, so I am leaving it alone.
interface Vlan552
 description CORE-NEXUS-L3
 ip address 10.8.52.2 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow monitor NETFLOW_MONITOR input
 ip flow monitor NETFLOW_MONITOR output
 standby 0 ip 10.8.52.1
 standby 0 priority 120
 standby 0 preempt
N5K-1#
no feature telnet
cfs eth distribute
feature ospf
feature pbr
feature hsrp
feature lacp
feature dhcp
feature vpc
feature lldp
feature vtp
!PEER-LINK
vrf context VPC-KEEPALIVE
interface Vlan550
  no shutdown
  ip address 10.8.50.2/24
vpc domain 5
  role priority 10
  peer-keepalive destination 10.8.50.3 source 10.8.50.2 vrf VPC-KEEPALIVE
  delay restore 150
  description 5K1 TO 5K2 PEER-LINK
  vpc peer-link
interface Ethernet1/9-10
!ETHERCHANNEL TO CORE1 & CORE2
  vpc 61
  vpc 62
interface Ethernet1/1-4
interface Ethernet1/45-48
!TO BLADE SWITCHES - 10G
interface port-channel51
  description BLADE-SW1
  speed 10000
  vpc 51
interface port-channel52
  description BLADE-SW2
  speed 10000
  vpc 52
interface port-channel53
  description BLADE-SW3
  speed 10000
  vpc 53
interface port-channel54
  description BLADE-SW4
  speed 10000
  vpc 54
interface port-channel55
  description BLADE-SW5
  speed 10000
  vpc 55
interface port-channel56
  description BLADE-SW6
  speed 10000
  vpc 56
interface Ethernet1/17
  channel-group 51 mode active
interface Ethernet1/19
  channel-group 52 mode active
interface Ethernet1/25
  channel-group 53 mode active
interface Ethernet1/27
  channel-group 54 mode active
interface Ethernet1/33
  channel-group 55 mode active
interface Ethernet1/35
  channel-group 56 mode active
!ROUTING VLANS
interface Vlan701
  no shutdown
  no ip redirects
  ip address 10.8.0.2/22
  hsrp 1
    preempt
    priority 120
    ip 10.8.0.1
  ip dhcp relay address 10.X.X.X
!USE FOR DEFAULT GATEWAY
interface Vlan552
  no shutdown
  no ip redirects
  ip address 10.8.52.32/24
  hsrp 1
    preempt
    priority 120
    ip 10.8.52.31
interface Vlan704
  no shutdown
  no ip redirects
  ip address 10.8.16.2/24
  hsrp 1
    preempt
    priority 120
    ip 10.8.16.1
interface Vlan751
  description CISCO-MGT
  no shutdown
  no ip redirects
  ip address 10.8.7.32/24
  hsrp 1
    preempt
    priority 120
    ip 10.8.7.31
interface loopback0
!ROUTING & OSPF
router ospf 1
  area 0.0.0.0 range 10.8.0.0/22
  area 0.0.0.0 range 10.8.7.0/24
  area 0.0.0.0 range 10.8.16.0/24
  area 0.0.0.0 range 10.8.52.0/24
!access-list 1 to allow only certain network to ssh
ip access-list 1
  10 remark : REMOTE ACCESS TO SWITCH FROM THESE IP
  20 permit ip 10.8.0.0/32 any
line console
  exec-timeout 15
line vty
  exec-timeout 15
  access-class 1 in
!SNMP (NOTE IT USES ACL 1 ALSO)
snmp-server contact NETWORK SUPPORT 123.456.789
snmp-server location 11 CISCO DR, SAN JOSE, CA 77077
snmp-server host 10.8.18.100 traps version 2c <KEY>
snmp-server host 10.8.18.100 source-interface Vlan751
!network-operator is for RO, network-admin is for RW
snmp-server community <RO> group network-operator
snmp-server community <RW STRING> group network-admin
snmp-server community <RW STRING> use-ipv4acl 1
!AUTHENTICATION & RADIUS
username NWADMIN password <XXXXX> role network-admin
aaa authentication login default group radius local
aaa accounting default group radius
radius-server host 10.X.X.X key XXXXX auth-port 1645 acct-port 1646 authentication accounting
ssh login-attempts 2
ssh key rsa 2048
login block-for 1800 attempts 5 within 90
login quiet-mode access-class 1
!ROUTE-MAP
ip access-list 150
  10 remark : ROUTE TO LA ENLAN
  20 remark : PBR DOESN.T SUPPPORT DENY . PERMIT BELOW EXCEPT TO 10.8.1.24
  30 permit ip 10.8.0.0/22 10.1.1.0/28
  40 permit ip 10.8.0.0/22 10.1.1.16/29
  50 permit ip 10.8.0.0/22 10.1.1.25/32
  60 permit ip 10.8.0.0/22 10.1.1.26/31
  70 permit ip 10.8.0.0/22 10.1.1.28/30
  80 permit ip 10.8.0.0/22 10.1.1.32/27
  90 permit ip 10.8.0.0/22 10.1.1.64/26
  100 permit ip 10.8.0.0/22 10.1.1.128/25
route-map TO_LA_ENLAN permit 10
  match ip address 150
  set ip next-hop 172.16.2.2
interface x
!MGT (OPTIONAL)
vrf context management
  ip route 0.0.0.0/0 10.8.7.1
interface mgmt0
  vrf member management
  ip address 10.X.X.X/24
!OTHER COMMANDS
no ip domain-lookup
ip domain-name XXXXX.com
ip name-server 10.XXXX
no ip source-route
no ip igmp snooping mrouter vpc-peer-link
clock timezone CST -6 0
clock summer-time CDT 1 Sun Apr 02:00 4 sun oct 02:00 60
cli alias name wrme copy run start
ntp server 10.X.X.X
boot kickstart bootflash:/n5000-uk9-kickstart.7.3.3.N1.1.bin
boot system bootflash:/n5000-uk9.7.3.3.N1.1.bin
logging server 10.X.X.X
N5K-2#
!PEER-LINK
vpc domain 5
  role priority 20
  peer-keepalive destination 10.8.50.2 source 10.8.50.3 vrf VPC-KEEPALIVE
  delay restore 150
interface Vlan550
  no shutdown
  ip address 10.8.50.3/24
  description KEEPALIVE - N5K2 TO N5K1
  speed 10000
  duplex full
  vpc peer-link
  duplex full
  channel-group 50 mode passive
  vpc 61
  vpc 62
  speed 10000
  vpc 51
  speed 10000
  vpc 52
  speed 10000
  vpc 53
  speed 10000
  vpc 54
  speed 10000
  vpc 55
  speed 10000
  vpc 56
!ROUTING VLANS
interface Vlan701
  no shutdown
  no ip redirects
  ip address 10.8.0.23/22
  hsrp 1
    preempt
    priority 110
    ip 10.8.0.1
interface Vlan550
  no shutdown
interface Vlan552
  no shutdown
  no ip redirects
  ip address 10.8.52.33/24
  hsrp 1
    preempt
    priority 110
    ip 10.8.52.31
interface Vlan704
  no shutdown
  no ip redirects
  ip address 10.8.16.3/24
  hsrp 1
    preempt
    priority 110
    ip 10.8.16.1
interface Vlan751
  no shutdown
  no ip redirects
  ip address 10.8.7.33/24
  hsrp 1
    preempt
    priority 110
    ip 10.8.7.31
!ROUTING & OSPF
router ospf 1
  area 0.0.0.0 range 10.0.21.16/28
3 REPLIES 3
nazimkha
Enthusiast
If you leave the link between the Nexus 5596 and the catalyst 6500 as L2 you may need to ensure that you are running 7.3(0)N1(1) code the Nexus 5596 as Dynamic routing over vPC or L3 vPC is only supported from this release.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/release/notes/7x/Nexus5500_Release_Notes_7x.html#pgfId-622079
Your configs looks okay, you may need to add 'layer3 peer-router' and peer-gateway under the vpc domain and also ensure the config is identical across both vPC switches.
As always all changes only in maintenance window :)
I'm running it ;)
CiscoGirl
Beginner
router ospf 1
interface Vlan552
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 standby 0 preempt
N5K-1#
no feature telnet
cfs eth distribute
feature ospf
feature pbr
feature hsrp
feature lacp
feature dhcp
feature vpc
feature lldp
feature vtp
!PEER-LINK
interface Vlan550
  no shutdown
vpc domain 5
  role priority 10
  delay restore 150
  vpc peer-link
  vpc 61
  vpc 62
  speed 10000
  vpc 51
  speed 10000
  vpc 52
  speed 10000
  vpc 53
  speed 10000
  vpc 54
  speed 10000
  vpc 55
  speed 10000
  vpc 56
!ROUTING VLANS
interface Vlan701
  no shutdown
  no ip redirects
  hsrp 1
    preempt
    priority 120
    ip 10.8.0.1
interface Vlan552
  no shutdown
  no ip redirects
  hsrp 1
    preempt
    priority 120
    ip 10.8.52.31
interface Vlan704
  no shutdown
  no ip redirects
  hsrp 1
    preempt
    priority 120
    ip 10.8.16.1
interface Vlan751
  no shutdown
  no ip redirects
  hsrp 1
    preempt
    priority 120
    ip 10.8.7.31
interface loopback0
!ROUTING & OSPF
router ospf 1
ip access-list 1
line console
  exec-timeout 15
line vty
  exec-timeout 15
  access-class 1 in
ssh key rsa 2048
!ROUTE-MAP
ip access-list 150
interface x
!MGT (OPTIONAL)
interface mgmt0
!OTHER COMMANDS
no ip domain-lookup
no ip source-route
ntp server 10.X.X.X
N5K-2#
!PEER-LINK
vpc domain 5
  role priority 20
  delay restore 150
interface Vlan550
  no shutdown
  speed 10000
  duplex full
  vpc peer-link
  duplex full
  vpc 61
  vpc 62
  speed 10000
  vpc 51
  speed 10000
  vpc 52
  speed 10000
  vpc 53
  speed 10000
  vpc 54
  speed 10000
  vpc 55
  speed 10000
  vpc 56
!ROUTING VLANS
interface Vlan701
  no shutdown
  no ip redirects
  hsrp 1
    preempt
    priority 110
    ip 10.8.0.1
interface Vlan550
  no shutdown
interface Vlan552
  no shutdown
  no ip redirects
  hsrp 1
    preempt
    priority 110
    ip 10.8.52.31
interface Vlan704
  no shutdown
  no ip redirects
  hsrp 1
    preempt
    priority 110
    ip 10.8.16.1
interface Vlan751
  no shutdown
  no ip redirects
  hsrp 1
    preempt
    priority 110
    ip 10.8.7.31
!ROUTING & OSPF
router ospf 1
