hustler0002
Beginner
6509 with Sup 720 configuration upgrade
I currently have this in our Sup720:
boot system flash bootflash:s72033-jk9o3sv-mz.122-17a.SX3.bin
boot bootldr sup-bootflash:s72033-psv-mz.122-17a.SX1.bin
I downloaded s72033-mp001-pz.122-33.SXH5
I read the documentation on Upgrading Software Images on Catalyst 6000/6500 Series Switches
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080116ff0.shtml
I was wondering do I copy the s72033-mp001-pz.122-33.SXH5 to the sup-bootflash and bootflash?  In the example it also uses disk0: but I get a <No device available>. Also keep in mind we're upgrading the application and maintanence partitions also. So this is a big upgrade and I've never done this before.
I guess the 2 things I want to know is:
1) Can I copy the s72033-mp001-pz.122-33.SXH5 to both the sup-bootflash and the bootflash?  Can I run it just copying it to the sup-bootflash?
2) It was my understanding that I only needed one image file for the upgrade but the documentation says I need
    "a. the main software image
     b. the bootloader image"
   Do I need another file?  I'm a little confused.  I did notice the files had different names and sizes and so do the ones on my current Sup 720.
And we are doing this tomorrow and I just happened to be reviewing the documentation one more time and somehow missed this. Any help would be appreciated.
TIA
Mike
1 ACCEPTED SOLUTION
You have the wrong file and not enough flash space. The file you need should be similar to the following:
IOS image for SUP720 MSFC3 - s72033-adventerprisek9_wan-mz.122-33.SXH8.bin
IOS Bootloader - s72033-boot-mz.122-33.SXH8.bin
ROMMON for 6700 series line cards - c2lc-rm2.srec.122-18r.S1
FPD upgrade - c6500-fpd-pkg.122-33.SXH8.pkg
From your other post, you don't have enough space in sup-bootflash:. The easiest way to do is put a 512MB CF card into disk0:.
Here is the instruction to upgrade the IOS
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080116ff0.shtml#sup720
Here is the instruction on the 6700 series LC ROMMON upgrade
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/rommon/OL_6143.html
HTH,
jerry
8 REPLIES 8
Jerry Ye
Can you post output of show mod? The image you've downloaded s72033-mp001-pz.122-33.SXH5 is a L2 only image. Just want to make sure this is what you want.
jerry
Mod Ports Card Type                                              Model                          Serial No.
  1    6  Firewall Module                                           WS-SVC-FWM-1       SAD080204VN
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD080300GL
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD0748015V
  4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD08030ANU
  5    2  Supervisor Engine 720 (Active)                   WS-SUP720-BASE     SAD080306JP
  6    0  Supervisor-Other                                         Unknown            Unknown
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD08030ATY
  8    8  8 port 1000mb GBIC Enhanced QoS          WS-X6408A-GBIC     SAL063557PC
Mod MAC addresses                               Hw    Fw               Sw                  Status
  1  0003.fead.a70c to 0003.fead.a713    3.0  7.2(1)           1.1(3)              Ok
  2  000e.83ea.725c to 000e.83ea.728b   1.3   12.2(14r)S5  12.2(17a)SX1 Ok
  3  000e.38ca.f8f8 to 000e.38ca.f927    1.3   12.2(14r)S5  12.2(17a)SX1 Ok
  4  000e.38ca.feb0 to 000e.38ca.fedf     1.3   12.2(14r)S5  12.2(17a)SX1 Ok
  5  000e.8315.f118 to 000e.8315.f11b  3.1  7.7(1)           12.2(17a)SX1 Ok
  6  0000.0000.0000 to 0000.0000.0000   0.0   Unknown      Unknown      Unknown
  7  0002.fcc2.5ab4 to 0002.fcc2.5ae3      1.3   12.2(14r)S5  12.2(17a)SX1 Ok
  8  000a.b79b.9208 to 000a.b79b.920f  2.1  5.4(2)          8.2(0.56)TET Ok
Mod Sub-Module                         Model                      Serial                 Hw     Status
  2 Centralized Forwarding Card WS-F6700-CFC       SAD0747021L   1.2    Ok
  3 Centralized Forwarding Card WS-F6700-CFC       SAD074403MA  1.2    Ok
  4 Centralized Forwarding Card WS-F6700-CFC       SAD0747096S   1.2    Ok
  5 Policy Feature Card 3             WS-F6K-PFC3A     SAD080304R8   2.1    Ok
  5 MSFC3 Daughterboard         WS-SUP720            SAD080304Z7   2.1    Ok
  7 Centralized Forwarding Card WS-F6700-CFC       SAD0747094L   1.2    Ok
Mod Online Diag Status
  1 Pass  2 Pass  3 Pass  4 Pass  5 Pass  6 Unknown  7 Pass  8 Pass
Do I have the right file?
HTH,
jerry
Jerry thanks for quick reply.
I had a question about the FPD upgrade file. What is it for? I did find the documentation
http://www.cisco.com/en/US/docs/routers/7200/configuration/feature_guides/fpd.html#wp1085780
Is there a specific order in upgrading?  I need to upgrade basically everything.
Here's what I know.
1. Upgrade the application partition from 1.1(3) to 2.3(5)
2. Upgrade the maintenance partition to 2.1(2) or higher
3. Upgrade the supervisor to 12.2(18)SXF2 or higher
4. Upgrade the application partition from 2.3(5) to 4.x
When do I upgrade the FPD?
TIA
Mike
mgalazka
Beginner
Do you have a CF card in the slot of your Sup720?  This is where you should store the IOS image, as the bootflash may not be large enough to hold the newer IOS images (or not big enough to hold two of them).  You will want to check your filesystems to see if you have a CF card, and if not, if you have enough free space in your bootflash for the new image.
In privileged mode, issue a "dir all-filesystems".  Depending on model of sup720, you should look for disk0:, slot0:, or sup-bootdisk:.
If none of these exist, then check the amount of free space in bootflash:.  If you have enough free space in your bootflash: you can copy the new image there, and then just change your configured boot variable to point to the new image.  Reload, and you should come up on the new image.
Looking at release notes for 12.2(33)SXH series, I see a lot of requirements for a minimum ROMMON version of 12.2(18r)S1... I would check the ROMMON version on your sup720 (show ver | inc ROM) and look at the release notes: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html to see if you need to upgrade your ROMMON to support 12.2(33)SXH5.
Hope this helps,
Matt
SUP720#dir all-filesystems
Directory of sup-bootflash:/
    1  -rw-    39950836  Jan 29 2004 22:57:54 -08:00  s72033-psv-mz.122-17a.SX1.bin
    2  -rw-       85604  Apr 13 2004 16:38:37 -08:00  debuginfo_20040414-003837
    3  -rw-       76970  Apr 14 2004 14:32:03 -08:00  debuginfo_20040414-223203
65536000 bytes total (25422204 bytes free)
Directory of sup-microcode:/
    1  -r--     3238574                      CWPA_version_10.10
    2  -r--     4499506                      CWTLC_version_10.10
    3  -r--     3719098                      CWPA2_version_10.10
    4  -r--    11627110                      DRACO2_MP
    5  -r--     4692586                      CHEVYS-LC
    6  -r--     5352130                      C2LC
    7  -r--     2253174                      MACEDON
    8  -r--      365198                      LCP_LX10100
    9  -r--      341036                      LCP_LX1000
   10  -r--      365702                      LCP_AX1000
   11  -r--      334596                      LCP_AX10100
   12  -r--      319982                      LCP_CPFAB
   13  -r--      645246                      LCP_CPGBIT
   14  -r--      632478                      LCP_CP10G
   15  -r--      711918                      LCP_CPMBIT2
   16  -r--      803134                      LCP_CPMBIT
39901980 bytes total (0 bytes free)
Directory of const_nvram:/
    1  -rw-        2116                      vlan.dat
129004 bytes total (126888 bytes free)
Directory of nvram:/
1918  -rw-       19862                      startup-config
1919  ----           5                      private-config
1920  -rw-       19862                      underlying-config
    1  ----           4                      rf_cold_starts
    2  ----          20                      persistent-data
1964024 bytes total (1942057 bytes free)
Directory of system:/
    2  dr-x           0                      memory
    1  -rw-       19862                      running-config
   12  dr-x           0                      vfiles
No space information available
Directory of bootflash:/
    1  -rw-           4  Apr 13 2004 14:50:49 -08:00  test.txt
    2  -rw-    42691624  Apr 13 2004 16:11:23 -08:00  s72033-jk9o3sv-mz.122-17a.SX3.bin
65536000 bytes total (22844116 bytes free)
Directory of dfc#7-bootflash:/
No files in directory
15990784 bytes total (15990784 bytes free)
Directory of dfc#4-bootflash:/
Directory of dfc#3-bootflash:/
    1  -rw-      298238  May 30 2005 12:54:11 -08:00  crashinfo_20050530-205411
15990784 bytes total (15692416 bytes free)
Directory of dfc#2-bootflash:/
This is what I get from a dir.  It looks like I have an older version of the ROMMON.  Can you tell me the file name I need to upgrade the ROMMON to? Is it
or
c6msfc3-rm2.srec.122-17r.SX7
I didn't see it in the upgrading the SUP720 documentation.  Also I don't think we have a CF card in the slot. Disk0 and Disk1 dir give a .
The version we have is 12.2(14r)s9 but I can't find the file anywhere.  Is the file usually saved somewhere like in the bootflash or can you delete it after it's been upgraded?
Jerry Ye
Hi Mike,
After double checking the documentation, none of your modules need FPD upgrade. It is for SIP SPA and SCC modules.
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/install_upgrade/6500series/6500trbl.html
HTH,
jerry
Thanks again for your help.  So I guess I need to get those 3 files from above and a 512 MB CF card to upgrade the SUP720. I'll do a little more reading and post if I have any more question.
Mike
