7200 E1 PRI
justanas1
Dear Sir,
i need to know how to use 7200 Router to connect 10 sites to the head quarter (7200 will be in the HQ) every site will be connected using two E1s, i also want to use this router as POP that users will be login from dialup.
please provide me with the partnumbers of the modules.
apaxson
It sounds like you already know what you want. I would call Cisco Sales, and have them get the part#'s for you.
From the looks of it, you need 20 E1 ports, and maybe a PRI or two, depending on how many users you plan of having dialed-up at once.
An E1 PRI can have 30 channels (if memory serves?), so that gives you 30 people dialed up at once.
Thank you sir,
i want the part number of the E1 and PRI modules.
i also want to know if i need digital modems or no
You can find out the part number and the code in the below link..
http://www.cisco.com/en/US/products/hw/modules/ps2033/ps2683/index.html
Also You don't need any digital modems at the router end...
regds
