10-13-2009 11:39 PM - edited 03-04-2019 06:21 AM
I'm trying to configure the following scheme :
[LAN]--[CPE]-------<ATM 7200 ETH>----
[LAN]--[CPE]-----
The 2 ATM PVC's (16/2055 and 16/2056) should be bonded together to get a
fully transparent L2 link without any routing involved.
I browsed through the Cisco documentation, especially the "Layer 2 local
switching" document at
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/fslocal.html
which says it's possible with the following config :
interface atm1/0
pvc 16/2055 l2transport
encapsulation aal5
pvc 16/2056 l2transport
encapsulation aal5
connect randomname atm1/0 16/2055 atm1/0 16/2056
The last command gives me the following error :
CONN: cannot connect two endpoints on the same interface
%CONN: Invalid Command
But the manual says :
"Starting with Cisco IOS Release 12.0(30)S, you can configure same-port
switching following the steps in this section. "
Can anybody tell me how to get this working? Is this a Cisco bug?
I'm running c7200p-advipservicesk9-mz.124-15.T1.bin on this box.
My hardware is :
Cisco 7206-VXR with PA-A3-OC3 for ATM connectivity and an NPE-G2 as a
processing engine.
Remco Bressers
Signet B.V.
Solved! Go to Solution.
10-15-2009 12:53 AM
Hello Remco,
the configuration looks like correct.
I post a pdf of troubleshooting ATM bridged PVCs
and links
http://www.cisco.com/en/US/tech/tk39/tk48/technologies_configuration_example09186a008009455f.shtml
And Q & A
http://www.cisco.com/en/US/tech/tk39/tk371/technologies_q_and_a_item09186a00800fb730.shtml#qa5
Also there is routed bridged encapsulation that could be an alternate way to do this.
I tested this several years ago and if I remember correctly it worked for me.
check also what the devices at the other end of PVCs expect in terms of ATM encapsulation and if they are using RFC 1483 bridged mode (that is they place an ethernet frame carrying an IP packet inside an ATM PDU).
the possible trick could be that of using a LAN interface to be placed in same briding group with the role of handling ethernet frames.
But this should be useful only if you want to route the IP packets.
Hope to help
Giuseppe
10-14-2009 12:05 AM
Hello Remco,
IOS releases numbering is more complex.
12.0S is a train for service provider that is still alive and used on high end routers.
you have 12.4(15)T1 and you would expect to be able to local switch on the same port.
Unfortunately, this is not the case.
changing IOS image could be considered but it requires care you may have some feature running that is not supported in 12.0S train.
I would try to use transparent bridging that is:
to create two point-to-point subinterfaces and to bridge between them
int atm1/0.2055 point-to-point
pvc 16/2055
enc aal5snap
no ip address
bridge-group 1
int atm1/0.2056 point-to-point
pvc 16/2056
enc aal5snap
no ip address
bridge-group 1
bridge 1 protocol ieee
Hope to help
Giuseppe
10-14-2009 12:08 AM
Hi Giuseppe,
Thanks for the reply! Does your solution work with my current configuration for other PVC's on PPPoA? I don't want to break things.
Especially the "bridge 1 protocol ieee" on the global level. This doesn't have any influence over other interfaces right?
10-14-2009 12:48 AM
Hello Remco,
you should be able to use PPPoA on other ATM subinterfaces
this applies only to interfaces members of this bridge-group and defines what type of STP is spoken.
Hope to help
Giuseppe
10-14-2009 12:51 AM
Great! I'll try this out on the lab overhere. If it's ok i can implement this on the live platform.
Thanks a million!
10-14-2009 01:49 AM
10-15-2009 12:20 AM
Hi Giuseppe,
I tried out the configuration, but it doesn't seem to work :(.
The configuration on the 7200 :
interface ATM1/0.162055 point-to-point
no ip redirects
no ip proxy-arp
no snmp trap link-status
bridge-group 10
pvc 16/2055
vbr-nrt 512 512
encapsulation aal5snap
interface ATM1/0.162056 point-to-point
no ip redirects
no ip proxy-arp
bridge-group 10
pvc 16/2056
vbr-nrt 512 512
bridge 10 protocol ieee
Have you got any tips for me?
Remco
10-15-2009 12:53 AM
Hello Remco,
and links
And Q & A
Hope to help
Giuseppe
10-15-2009 01:28 AM
Thanks again!
Personally i was thinking about me not configuring "bridge irb" on the box. This should be enabled right?
Is this command 'safe' to enter e.g. will it interfere my running interfaces (routing, switching). ?
Thanks!
09-22-2010 06:33 AM
Hi Giuslar,
I am using a different IOS and getting the same error
Router(config)#do sho ver | in .bin
System image file is "disk0:c7301-adventerprisek9-mz.122-33.SRD4.bin"
Router(config)#do sho run int atm1/0
Building configuration...
Current configuration : 220 bytes
interface ATM1/0
no ip address
no atm enable-ilmi-trap
pvc 1/100 l2transport
encapsulation aal5
pvc 1/200 l2transport
encapsulation aal5
pvc 2/100 l2transport
encapsulation aal5
end
Router(config)#connect test atm 1/0 1/100 atM 1/0 2/100
Router(config)#connect test atm 1/0 1/100 atM 1/0 1/100
Router(config)#connect test atm 1/0 1/100 atM 1/0 1/200
Thx,
Hadi
