7206VXR router POS interface loopback
Pradeep H A
Level 3
Level 3
Hi All,
We have a 7206vxr router with a pos interface: its PA-POS-1OC3 card currently in up/down status:
We already repalced the card but still same (up/down) condition.
R01#sh int pos 1/0
POS1/0 is up, line protocol is down
  Hardware is Packet over Sonet
  Description: PPP link to MPLS PE
  Internet address is *****************
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Encapsulation PPP, LCP ACKsent, crc 32, loopback not set
  Keepalive set (10 sec)
  Scramble enabled
  Last input 00:00:05, output never, output hang never
  Last clearing of "show interface" counters 4d12h
  Input queue: 0/1000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 4/40 (size/max)
     75362 packets input, 1356464 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
              0 parity
     4 input errors, 7 CRC, 0 frame, 0 overrun, 0 ignored, 3 abort
     1628 packets output, 25438 bytes, 0 underruns
     0 output errors, 0 applique, 5469 interface resets
     1 carrier transitions
I tried putting an internal loop on the interface (new card): still it doesnt come up! as per my knowledge internal loopback means a loop within the card right? then its not coming up for internal loop also means even the new card has gone faulty or do I need replace the whole chasis?
R01#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R01(config)#int pos 1/0
R01(config-if)#loopback ?
  internal  internal
  line      line
R01(config-if)#loopback internal
R01#sh int POS1/0
  Internet address is 192.168.211.49/30
  Encapsulation PPP, LCP Listen, crc 32, loopback set (internal)
  Scramble enabled
  Last input 00:00:54, output never, output hang never
  Output queue: 0/40 (size/max)
     75090 packets input, 1351616 bytes, 0 no buffer
              0 parity
     4 input errors, 7 CRC, 0 frame, 0 overrun, 0 ignored, 2 abort
     0 output errors, 0 applique, 5431 interface resets
     0 carrier transitions
paolo bevilacqua
Do something else: loopback the circuit.
The objective is to prove to telco that the circuit is faulty, not the router.
vblaha
Community Member
Did you ever figure this out?
Yes Vblaha,
We replaced the chasis & WIC card with same configuration. The link came up.
So basically I understand it was chasis fault that made the WIC card not respond to even an internal loopback
Any more suggestions on this?
