7246 interface force 100mb
b.withrow
I am trying to force f0/0 on a 7246 router to 100/full. But I don't see the speed command as an option on the interface. I was able to force full duplex but not speed. Is there a reason why? I assume the answer is easy, but I've never seen this before.
spremkumar
Level 9
Level 9
hi
I feel you are talking about 7206 series router..
Is your current speed visible/showing up when you issue show interface command ??
Also can you check top which type the ethernet port belongs to ? you can do this by issuing show diag command in your cli and check for the type.
In some cases the ethernet ports turned out to be normal ethernet instead of fastethernet in that case you will hve to live with only 10Mbps but since you have mentioned F0/0 i assume its a onboard port which comes up with the NPE and ofcourse you will be able to change the speed.
do post out the show version output here which will help to gather more info about your ios and interface type installed..
regds
It is a 7246vxr
IOS (tm) 7200 Software (UBR7200-K8P-M), Version 12.2(15)BC2h, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Sat 30-Jul-05 12:47 by kellythw
Image text-base: 0x60008EB0, data-base: 0x61452000
ROM: System Bootstrap, Version 12.0(19990210:195103) [12.0XE 105], DEVELOPMENT SOFTWARE
BOOTLDR: 7200 Software (UBR7200-BOOT-M), Version 12.0(10)SC1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
host name uptime is 33 weeks, 3 days, 6 hours, 15 minutes
System restarted at 03:16:20 CDT Tue Sep 13 2005
Running default software
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco uBR7246VXR (NPE300) processor (revision D) with 122880K/40960K bytes of memory.
Processor board ID SAB0430002C
R7000 CPU at 262Mhz, Implementation 39, Rev 2.1, 256KB L2, 2048KB L3 Cache
6 slot VXR midplane, Version 2.0
Last reset from power-on
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Cable Modem network interface(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
host name#sho int f0/0
FastEthernet0/0 is up, line protocol is up
Hardware is DEC21140A, address is 0002.fc84.2400 (bia 0002.fc84.2400)
Description:
Internet address is
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 7/255, rxload 13/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d05h
Input queue: 0/75/0/172 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 5360000 bits/sec, 1203 packets/sec
5 minute output rate 2816000 bits/sec, 1120 packets/sec
121897272 packets input, 167045261 bytes
Received 159899 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
113809838 packets output, 1274866998 bytes, 0 underruns
0 lost carrier, 0 no carrier
host name#conf t
Enter configuration commands, one per line. End with CNTL/Z.
host name(config)#int f0/0
host name(config-if)#speed?
