7606-s Manufacture Date
dtom
Not sure if this is the correct place for this question or ont...
Is there a way we can tell what the manufacture date is on a Cisco product?
Iulian Vaideanu
Level 4
Level 4
Yes, there is (well, not the exact date, but the week of the year):
http://jhigham.blogspot.ro/2010/10/cisco-date-of-manufacture-from-serial.html
For example, SAL17278M0Q (a DFC3CXL we have) was manufactured during week 27 of 2013.
5 Replies 5
Iulian Vaideanu
Level 4
Level 4
I tried the "sh ver" command on our 7606 and did not see any serial number:
mr-METRO#sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRC4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 11-May-09 20:44 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRB4, RELEASE SOFTWARE (fc1)
mr-METRO uptime is 20 weeks, 1 day, 13 hours, 10 minutes
Uptime for this control processor is 20 weeks, 1 day, 13 hours, 11 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 17:55:10 PDST Tue Sep 10 2013
System image file is "disk0:c7600rsp72043-adventerprisek9-mz.122-33.SRC4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.0) with 851968K/65536K bytes of memory.
Processor board ID FOX1148G5GL
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
2  controllers (40 GigabitEthernet).
443 Virtual Ethernet interfaces
68 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
mr-METRO#
Not sure if I am doing something wrong here...
"show inventory" will give you a lot of serial numbers
Is the chart referenced in John Higham's blog post still a valid reference? And if it is, I assume that the years would simply keep incrementing by one as they years go out beyond 2008?
Yes it is.
