ā10-01-2018 07:26 AM - edited ā03-05-2019 10:57 AM
819 - Cellular interface interface - going down after some time.
do any body have solution for that.
Profile gone permanently down after an hour .
sh run
chat-script hspa-R7 "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
chat-script LTE "" "AT!CALL" TIMEOUT 20 "OK"
cts logging verbose
controller Cellular 0
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string hspa-R7
dialer-group 1
no peer default ip address
async mode interactive
routing dynamic
interface FastEthernet0
switchport access vlan 99
no ip address
duplex half
speed 100
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
ip address 10.1.98.254 255.255.255.0
ip nat inside
duplex half
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Wlan-GigabitEthernet0
no ip address
interface wlan-ap0
no ip address
interface Vlan1
no ip address
interface Vlan99
ip address 10.1.99.254 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Cellular0 overload
ip nat inside source route-map internet interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip permit
route-map internet permit 10
match ip address 101
access-list 1 permit any
access-list 101 permit ip 10.1.98.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
exec-timeout 0 0
password cisco
script dialer hspa-R7
login
modem InOut
no exec
transport input all
line vty 0 5
password Cisc0123
login
transport input telnet
scheduler allocate 20000 1000
end
Solved! Go to Solution.
ā10-01-2018 09:55 AM
I have made some changes to your configuration (marked in bold):
sh run
cts logging verbose
interface Cellular0
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
dialer-group 1
routing dynamic
no ip address
duplex half
speed 100
no ip address
no ip address
no ip address
ip nat inside
duplex half
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
no ip address
interface wlan-ap0
no ip address
interface Vlan1
no ip address
interface Vlan99
ip nat inside
no ip http server
--> no ip nat inside source route-map internet interface Cellular0 overload
--> no route-map internet permit 10
--> no access-list 1 permit any
access-list 1 permit 10.1.98.0 0.0.0.255
access-list 1 permit 10.1.99.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
exec-timeout 0 0
password cisco
login
modem InOut
no exec
transport input all
line vty 0 5
password Cisc0123
login
end
sh run
cts logging verbose
interface Cellular0
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
dialer-group 1
routing dynamic
no ip address
duplex half
speed 100
no ip address
no ip address
no ip address
ip nat inside
duplex half
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
no ip address
interface wlan-ap0
no ip address
interface Vlan1
no ip address
interface Vlan99
ip nat inside
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
exec-timeout 0 0
password cisco
login
modem InOut
no exec
transport input all
line vty 0 5
password Cisc0123
login
end
ā10-01-2018 10:03 PM
ā10-02-2018 09:23 AM
post the full config again including the changes you have applied...
