857 ADSL Problems
evansag
I am having problems getting the ADSL interface to connect. Is anyone elese havving issues? I am using Demon.
Below are the relevant configs I am using,
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
description $ES_WAN$$FW_OUTSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 2
interface Dialer1
description $FW_OUTSIDE$
ip address xxxxxxxxxxxx
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect fwrule out
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxxx
ppp chap password xxxxxxxxx
6 Replies 6
nethelper
Level 3
Level 3
try ´dsl operating-mode ansi-dmt´ instead of ´auto´. Also, are you connecting to an ISP ? Try PAP authentication:
ppp authentication pap callin
ppp pap sent-username user@demon.com password password
The username and password need to be what your provider has given you...
Can you try this and see if it helps ?
Nethelper
I changed the ATM interface from dsl operating-mode 'auto' with ansi-dmt as suggested.This seemed to improve connectivity as the CO led remained solid for 30s before dropping off.
debug logs below. Dialer debugs look most promising
Thanks for your help.
debug ppp neg
000124: *Jan 6 18:58:37.007 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
000125: *Jan 6 18:58:41.223 GMT: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
000126: *Jan 6 18:58:41.223 GMT: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
000127: *Jan 6 18:58:41.223 GMT: Vi2 PPP: Using dialer call direction
000128: *Jan 6 18:58:41.223 GMT: Vi2 PPP: Treating connection as a callout
000129: *Jan 6 18:58:41.223 GMT: Vi2 PPP: Phase is ESTABLISHING, Active Open
000130: *Jan 6 18:58:41.223 GMT: Vi2 PPP: No remote authentication for call-out
000131: *Jan 6 18:58:41.223 GMT: Vi2 LCP: O CONFREQ [Closed] id 32 len 14
000132: *Jan 6 18:58:41.223 GMT: Vi2 LCP: MRU 1478 (0x010405C6)
000133: *Jan 6 18:58:41.223 GMT: Vi2 LCP: MagicNumber 0x14FD518E (0x050614FD518E)
000134: *Jan 6 18:58:42.279 GMT: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
000135: *Jan 6 18:58:42.279 GMT: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
000136: *Jan 6 18:58:42.279 GMT: Vi2 PPP: Sending Acct Event[Down] id[11]
000137: *Jan 6 18:58:42.279 GMT: Vi2 LCP: State is Closed
000138: *Jan 6 18:58:42.279 GMT: Vi2 PPP: Phase is DOWN
000139: *Jan 6 18:58:43.295 GMT: %LINK-3-UPDOWN: Interface ATM0, changed state to down
000140: *Jan 6 18:58:44.295 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
Debug ATM Events
000245: *Jan 6 19:02:11.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000246: *Jan 6 19:02:12.115 GMT: atmsar_vc_tx_start(81C0A260).
000247: *Jan 6 19:02:12.115 GMT: ATM0:atmsar_dequeue_pak, dequeued a pak = 0x81
B19518
000248: *Jan 6 19:02:12.115 GMT: atmsar_transmit_pak_wrapper: deq(81B19518). vc
d: 1.atmsar_transmit_pak_wrapper : encap = Data
000252: *Jan 6 19:02:15.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000253: *Jan 6 19:02:16.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000254: *Jan 6 19:02:17.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000256: *Jan 6 19:02:18.955 GMT: ATM0: atmsar_atm_get_stats,vcinfo = 0x0
000257: *Jan 6 19:02:19.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000258: *Jan 6 19:02:20.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000259: *Jan 6 19:02:21.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000260: *Jan 6 19:02:22.131 GMT: atmsar_vc_tx_start(81C0A260).
000261: *Jan 6 19:02:22.131 GMT: ATM0:atmsar_dequeue_pak, dequeued a pak = 0x82
0A57BC
000262: *Jan 6 19:02:22.131 GMT: atmsar_transmit_pak_wrapper: deq(820A57BC). vc
000263: *Jan 6 19:02:22.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000264: *Jan 6 19:02:23.143 GMT: ATM0: vcd = 1, safe_start called from periodic
Debug atm state
000306: *Jan 6 19:03:13.123 GMT: Changing vc 0/38vc-state to ATM_VC_SHUTTING_DOWN
000307: *Jan 6 19:03:13.123 GMT: Changing vc 0/38vc-state to ATM_VC_NOT_IN_SERVICE
debug dialer events
000327: *Jan 6 19:05:12.747 GMT: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
000328: *Jan 6 19:05:12.747 GMT: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
000329: *Jan 6 19:05:13.823 GMT: %LINK-3-UPDOWN: Interface ATM0, changed state to down
000330: *Jan 6 19:05:14.823 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
000331: *Jan 6 19:05:15.239 GMT: Di1 DDR: Cannot place call, no dialer string set
000332: *Jan 6 19:05:15.239 GMT: Di1 DDR: Cannot place call, no dialer string set
000333: *Jan 6 19:05:27.747 GMT: Vi2 DDR: re-enable timeout
cns-chalkida
Could you please post your "show ver" output?
I would like to see if you are using a 12.3 or a 12.4 IOS.
IOS is v12.3(10.3)T2 as per below
#sh ver
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.3(8)YI2, RE
LEASE SOFTWARE (fc1)
Synched to technology version 12.3(10.3)T2
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 14-Jun-05 20:08 by ealyon
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
ROM: Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.3(8)YI
2, RELEASE SOFTWARE (fc1)
esolutions uptime is 2 minutes
System image file is "flash:c850-advsecurityk9-mz.123-8.YI2.bin"
Cisco 857W (MPC8272) processor (revision 0x200) with 59392K/6144K bytes of memor
y.
Processor board ID FHK09502426
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
1 802.11 Radio
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
I have just upgraded it to
c850-advsecurityk9-mz.124-4.T1.bin (latest release v12.44 T1)
And sadly it has made no difference.
hostname Router
logging queue-limit 100
ip subnet-zero
ip cef
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
--More-- !
no voice hpi capture buffer
no voice hpi capture destination
interface Ethernet0
ip address 192.5.17.15 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
--More-- ip mtu 1492
hold-queue 224 in
interface ATM0.1 point-to-point
ip mtu 1492
pvc 1/33
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname xxxxert
ppp chap password 0 xxxxx
ppp pap sent-username xxxx password 0 xxxxx
ip nat inside source list 1 interface Dialer1 overload
ip classless
--More-- ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 1 permit 192.5.17.0 0.0.0.255
access-list 101 permit tcp any any eq 443
call rsvp-sync
please try out this configuration.
Regds
Binoy.
Please rate if it helps:
