06-29-2006 01:53 AM - edited 03-03-2019 01:10 PM
Small brench office; I have a 857 configured for InterNet access via ADSL (singtle static IP).
I need also to manage the router from outside; with the old router and with the PIX there is no problem.
I think there are some problems with the ACLs, but I can not find the solution.
Some idea or suggestion?
Claudio
06-29-2006 09:42 PM
hi
Are you trying to do telenet or trying some other NMS tool ?
if possible do post out the config of the same with the kinda access you require to have on this equipment..
regds
06-29-2006 10:15 PM
