866VAE-K9 Modem/AUX Problem
Hi Everyone,
I am currently observing some strange behavior of 866VAE-K9 router which might be a bug or my mistake, so I would very much appreciate your suggestions...
The 866VAE-K9 router has a single physical AUX/CON port.
The documentation states that in order to use AUX with a modem
one has to:
line con 0
modem enable
If I do this, some process starts on the line 1 and prevents
using of chat scripts and reverse telnet:
start-chat Dialout1 aux 0
% Chat script can not be run on line running other process
telnet 192.168.10.1 2001
Trying 192.168.10.1, 2001 ...
% Connection refused by remote host
If I clear line 1, and immediately after that start a chat script,
then it works (telnet hangs on at "asserting DTR"), but if I wait for
several seconds the line 1 becomes busy again...
Your suggestions/ideas are very appreciated!
sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
* 1 AUX 9600/9600 - - - - - 1 0 0/0 -
* 2 VTY - - - - - 1 0 0/0 -
* 3 VTY - - - - - 2 0 0/0 -
4 VTY - - - - - 0 0 0/0 -
5 VTY - - - - - 0 0 0/0 -
6 VTY - - - - - 0 0 0/0 -
Mainz(config-line)#
Mainz(config-line)#
Mainz(config-line)#do sh users
Line User Host(s) Idle Location
1 aux 0 idle 00:01:05 192.168.10.1
* 2 vty 0 jip idle 00:00:00 192.168.10.10
3 vty 1 jip 192.168.10.1 00:01:05 192.168.10.10
Interface User Mode Idle Peer Address
