10-06-2016 04:58 AM - edited 03-05-2019 07:13 AM
Hi All,
First off apologies but I am new to CLI and an trying to setup an ipsec vpn from iPhone/ipad to router.
I've setup Easy VPN Server and remote on an 867VAE using CCP and I am able to connect to server and ping vlan1 interface but cant ping or get to any local ips.
Could someone have a look at my config and see where I am going wrong? Is it a routing issue through the tunnel? Thanks for the help. Not sure if I'm giving enough info ....
10-07-2016 06:17 AM
Any help please? Thanks
10-10-2016 11:13 AM
can you post the output of 'show version' from your 867VAE ?
CiscoISR#show version
10-12-2016 08:57 AM
Show Version is below, Thanks
Cisco IOS Software, C860 Software (C860VAE-ADVSECURITYK9-M), Version 15.6(2)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 08-Jul-16 08:36 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M3, RELEASE SOFTWARE (fc1)
CiscoISR uptime is 6 days, 5 minutes
System returned to ROM by reload at 16:48:34 PCTime Thu Oct 6 2016
System image file is "flash:c860vae-advsecurityk9-mz.156-2.T1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 867VAE-K9 (revision 0.3) with 234496K/26624K bytes of memory.
Processor board ID GMK201900WL
