871 high CPU utilization
catalin.stan
I have a 871 and when I'm downloading a bigger file (over 100 MB) or uploading via FTP the CPU goes to 99%.
I have tested this with basic configuration (only nat and dhcp service configured). I have install the latest IOS version that is supported on the router (c870-advipservicesk9-mz.124-24.T8.bin) but I still have the same problem.
Can someone please let me know if this is a normal behavior for 871. Will a flash/RAM upgrade will help?
Thank you
35 Replies 35
I believe that is because all L3 interfaces (your SVIs 1 & 192) are all typically handled that way. Any packets on an SVI showing under 'Processor' will be related to packets shown under 'sh ip cef switching stats' .
I can't explain the issue with FTP. Does transfer initiate or timeout?
The FTP transfer is succesfull but in this time nothing else works. This also happens when I try to download a large file via http.
For example if I download 1 GB file, nobody else can use the network.
That sounds like a problem potentially caused by NAT. Perhaps NAT'ing to a pool with a single 'outside' address instead of using PAT and sharing that 'outside' address amoungst all the internal users.
Any chance you can post your router config?
Router#sh run
Building configuration...
Current configuration : 1434 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot system flash:c870-advsecurityk9-mz.124-24.T8.bin
boot system flash:c870-advipservicesk9-mz.124-24.T8.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp pool LAN192
   network 192.168.12.0 255.255.255.0
   default-router 192.168.12.1
   dns-server 8.8.8.8
ip cef
no ipv6 cef
archive
log config
  hidekeys
ip ssh version 1
interface FastEthernet0
interface FastEthernet1
switchport access vlan 192
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address dhcp
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1360
interface Vlan192
ip address 192.168.12.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0
no ip http server
no ip http secure-server
ip nat inside source list NAT_ACL interface Vlan1 overload
ip access-list extended NAT_ACL
permit ip 192.168.12.0 0.0.0.255 any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Ok, your NAT command is legit.
This may be an issue with the NAT table filling up, but highly unlikely as it is huge! Perhaps it is the connection timeouts...?
Initiate a large download and also attempt to acces other webpages and run the following commnads:
clear nat counters
clear ip nat translations
sh ip nat translations
sh ip nat stats
This seems to be OK:
Router#sh ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
tcp 192.168.175.77:54154 192.168.12.2:54154 173.194.39.160:443 173.194.39.160:443
tcp 192.168.175.77:54169 192.168.12.2:54169 173.194.39.175:443 173.194.39.175:443
tcp 192.168.175.77:58310 192.168.12.2:58310 157.55.236.79:443 157.55.236.79:443
tcp 192.168.175.77:54180 192.168.12.2:54180 93.115.243.142:80 93.115.243.142:80
udp 192.168.175.77:59642 192.168.12.2:59642 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:52575 192.168.12.2:52575 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:53183 192.168.12.2:53183 8.8.8.8:53       8.8.8.8:53
tcp 192.168.175.77:54158 192.168.12.2:54158 173.194.39.183:443 173.194.39.183:443
tcp 192.168.175.77:54160 192.168.12.2:54160 173.194.112.138:443 173.194.112.138:443
tcp 192.168.175.77:54161 192.168.12.2:54161 173.194.39.175:443 173.194.39.175:443
tcp 192.168.175.77:54164 192.168.12.2:54164 173.194.39.167:443 173.194.39.167:443
tcp 192.168.175.77:54167 192.168.12.2:54167 173.194.39.163:443 173.194.39.163:443
tcp 192.168.175.77:54181 192.168.12.2:54181 157.55.152.112:80 157.55.152.112:80
tcp 192.168.175.77:54182 192.168.12.2:54182 157.55.152.112:80 157.55.152.112:80
tcp 192.168.175.77:54183 192.168.12.2:54183 131.253.61.80:443 131.253.61.80:443
tcp 192.168.175.77:54184 192.168.12.2:54184 199.7.54.72:80   199.7.54.72:80
tcp 192.168.175.77:54185 192.168.12.2:54185 199.7.54.72:80   199.7.54.72:80
tcp 192.168.175.77:54186 192.168.12.2:54186 23.37.248.70:443 23.37.248.70:443
tcp 192.168.175.77:54188 192.168.12.2:54188 131.253.61.80:443 131.253.61.80:443
tcp 192.168.175.77:54189 192.168.12.2:54189 131.253.61.80:443 131.253.61.80:443
tcp 192.168.175.77:54190 192.168.12.2:54190 95.100.217.28:443 95.100.217.28:443
tcp 192.168.175.77:54191 192.168.12.2:54191 95.100.217.28:443 95.100.217.28:443
tcp 192.168.175.77:54192 192.168.12.2:54192 95.100.217.28:443 95.100.217.28:443
udp 192.168.175.77:54445 192.168.12.2:54445 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:54697 192.168.12.2:54697 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:54798 192.168.12.2:54798 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:55941 192.168.12.2:55941 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:56085 192.168.12.2:56085 148.198.145.2:161 148.198.145.2:161
udp 192.168.175.77:58369 192.168.12.2:58369 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:59723 192.168.12.2:59723 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:60652 192.168.12.2:60652 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:62945 192.168.12.2:62945 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:63514 192.168.12.2:63514 8.8.8.8:53       8.8.8.8:53
udp 192.168.175.77:64679 192.168.12.2:64679 8.8.8.8:53       8.8.8.8:53
Router#sh ip nat statistics
Total active translations: 48 (0 static, 48 dynamic; 48 extended)
Peak translations: 5255, occurred 00:40:46 ago
Outside interfaces:
  Vlan1
Inside interfaces:
  Vlan192
Hits: 1562425  Misses: 0
CEF Translated packets: 1558765, CEF Punted packets: 3661
Expired translations: 18884
Dynamic mappings:
-- Inside Source
[Id: 1] access-list NAT_ACL interface Vlan1 refcount 48
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Something about you nat translations doesn't look right. what's the output from:
sh ip int br
Router#sh ip inter brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              unassigned      YES NVRAM  administratively down down
NVI0                       unassigned      YES unset  administratively down down
Vlan1                      192.168.175.77  YES DHCP   up                    up
Vlan192                    192.168.12.1    YES NVRAM  up                    up
That checks out too.
Do you know what your download speed hits when all other internet access goes? If it is anywhere near 12.5Mbps then you have hit the limit of the router.
At that point I'm not sure how it will prioritse requests. Looks like FIFO so it maintains your download but drops everything else.
My download speed is arorund 300 kbps.
If I download a smaller file (90 MB) everything works fine. The problem appears only with large files.
So if you choose a +100Mb as soon as you start the download the internet is in accessible to other users? Or is is it once you manage to download 100mb+ that the internet becomes unavailable to other users.
If it is the latter then it sounds like a buffer or maybe NAT table issue.
Although I suprised no other 871 users have raised this issue!
The problem appears immediatly after I start the download. If I try to download a big file directly form the browser the processor goes up even before I press the "Save File" button.
I have 2 routers (same model) and the issue is the same on both.
OK my final suggestion
Why have you got the following defined in vlan1:
...if you can't accoutnfor it's includion in the config, then maybe try removing it:
int vlan1
no ip tcp adjust-mss 1360
...see if that makes a difference.
int vlan1
That does not change anything. Adjust-mss is for PPPoE connections, not performance.
I even tryed to upgrade the ram. I have just installed a 64 M on the router. I know have 192M. Still the same problem.
