871 Logging Interface & PPPoE
Hi All,
Seeing a strange issue on an 871,
I've defined a Dialler interface Dialler 10 for PPPoE, It comes up and establishes with no issue.
When I shut the Dialler interface I keep getting the log line "%LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up" which just repeats until I bring up the dialler again.
See below
rt-01(config)#int Di10
rt-01(config-if)#sh
rt-01(config-if)#
May  2 10:16:31.585: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di10
May  2 10:16:31.585: Di10 DDR: dialer shutdown complete
May  2 10:16:31.593: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
rt-01(config-if)#
May  2 10:16:31.601: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
rt-01(config-if)#
May  2 10:16:33.585: %LINK-5-CHANGED: Interface Dialer10, changed state to administratively down
rt-01(config-if)#
May  2 10:16:53.722: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
rt-01(config-if)#
May  2 10:17:15.995: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Any Idea what might be causing this this to keep logging?
Mark
5 Replies 5
Philip D'Ath
If you are using a lesser version, try upgrading the IOS to a gold star release like 15.1.4M10 and see if the same issue happens.
https://software.cisco.com/download/release.html?mdfid=279624003&softwareid=280805680&release=15.1.4M10&relind=AVAILABLE&rellifecycle=MD&reltype=latest
You could also try block it from logging using discriminator or no logging event link-status under the int
Hi Mark, Sorry for the delay, I'd rather not mask the problem by just turning off logging
Hi Philip, Sorry for the delay, I'm currently running the latest and greatest IOS for this device
So you are running 15.1.4M10?
