877 web page problem
stephen.stack
Level 4
Level 4
Hi Guys,
Hope someone can help me here. I have a cisco 877 that is really not behaving as it should. I am problems accessing some websites, Microsofts in paticular. and Hotmail via outlook express.
I had set MTU settings on it the same as i had for the 837 which was
Int e0
ip tcp adjust-mss 1452
int dialer0
ip mtu 1492
These settings do not have the desired effected to the 877
Any ideas. I am working in Ireland on Eircoms ADSL network.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
rmcarthur
Hi Stephen, do you have the firewall configured?
If so, try temporarily disabling it and see if the symptoms clear up.
If they do you likely need a java-list for the http inspection rule.
ip insp name myfw http java-list 10
access-list 10 permit any
Be as tight or as loose as you need to be with the access-list.
Hope this helps.
Ross
