881 Interface ports
dameon.boyle
Beginner
Beginner
Does anyone know how many of the 881 switch interface ports can be used as router ports, have used the 877 etc where i can use 2 but need a low cost router that supports 3 for routing. (needs to be physical ports)
Amit Aneja
Participant
Participant
You won' t be able to use the L2 ports as L3 on this router, the LAN ports are strictly L2 on this router.
Edison Ortiz
Hall of Fame Mentor Hall of Fame Mentor
Hall of Fame Mentor
As stated, they are strictly L2 ports but you can configure multiple SVIs and associate the SVIs to the ports.
For instance
interface fastethernet0
switchport access vlan 1
interface fastethernet1
switchport access vlan 2
interface fastethernet2
switchport access vlan 3
interface vlan 1
ip add 1.1.1.1 255.255.255.0
interface vlan 2
ip add 2.2.2.2 255.255.255.0
interface vlan 3
ip add 3.3.3.3 255.255.255.0
and route between Vlans.
Edison
