Highlighted
Beginner
887 AUX port configuration
I have spent a day trying to get the console / AUX port of an 887 to answer a call in (simple modem on aux port for remote configuration)
I believe that all i need on the line con 0 is "modem enable" and then i should configure line aux 0 as normal.
can anyone post a working config ?
regards, Will
2 REPLIES 2
Highlighted
Beginner
Re: 887 AUX port configuration
Hi Will,
Have you had any joy?
Highlighted
Beginner
config required is just modem enable and then configure line 1 as normal for aux port. -
my issue traced to issues with the modem - remember to initialise the modem correctly.
Will
