887VA VDSL2 configuration
cg1network
I have a Cisco 887VA router that I'm trying to connect to a VDSL2 service.
I'm getting this error when the VDSL2 service is plugged in:
%VDSL_DAEMON-4-TRAINMODE_NOT_SUPPORTED: ATM transport mode is not supported on VDSL2.
Here is the controller details:
Controller VDSL 0 is DOWN
Daemon Status:           Establishing Link
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'BDCM'
Chip Vendor Specific:   0x0000                   0x939B
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:     887VA-M- 15.1(4)M
Serial Number Far:
Modem Version Near:    15.1(4)M
Modem Version Far:     0x939b
Modem Status:            Idle
DSL Config Mode:         VDSL2
Trained Mode:
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON
Heres is the config:
interface Ethernet0
description $ETH-WAN$
ip address dhcp
ip tcp adjust-mss 1412
pppoe-client dial-pool-number 1
interface ATM0
no ip address
no atm ilmi-keepalive
shutdown
interface Vlan1
description LAN
ip address 10.0.0.20 255.0.0.0
ip nat inside
ip virtual-reassembly in
interface Dialer1
description Dialer interface for VDSL
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication pap chap ms-chap callin
ppp chap hostname *********
ppp chap password 0 *******
ppp ipcp address accept
no cdp enable
ip nat inside source list NAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended nat
permit ip 10.0.0.0 0.255.255.255 any
remark Access list for NAT
dialer-list 1 protocol ip permit
9 Replies 9
paolo bevilacqua
Interface can't train up, try another router for verification or check with telco.
I don't have another cisco router with a vdsl interface, i have tested the basic router that was provided by my ISP and that connects fine.
That's what I meant, try updating IOS and/or VDSL firmware. Worst case you have to use ISP router in bridge mode and cisco PPPoE on Vlan interface.
FWIW...
I have an 887VA and VDSL2 (PTM) from an ISP working.
They don't use PPPoE so I'm not sure this will help any that require it.
All I had to stop using ATM interfaces and use interface E0
(no subinterface as recommended elsewhere) and then
controller vdsl 0
operating mode vdls2
James Neilson
Try:
conf t
wan mode ethernet
exit
controller vdsl operating mode auto
I have updated the VDSL firmware and am now getting
%VDSL_DAEMON-4-TRAINMODE_NOT_SUPPORTED: UNKNOWN transport mode is not supported on VDSL2.
I have changed the vdsl operating mode to auto, but the "wan mode ethernet" isn't a recognized command
That is not an error just a warning and is not related to the problem.
Unless you can get Cisco Tac into looking why the router doesn;t sync with the particular ISP DLSAM, you will need to use the ISP router as mentioned above.
I had the same err-message this morning, in my case i did the following and fixed.
(config)#controller vdSL 0
(config-controller)#operating MOde adsl2+
there are other options under this tab, apply the one fits your SP line or try all 1 by 1 till its up-up
adsl1 ITU G.992.1
adsl2 ITU G.992.3
adsl2+ ITU G.992.5
ansi ANSI T1.413
auto auto detect mode
vdsl2 ITU G.993.2
cg1network
I have finally got it working, my ISP sent an engineer and he fixed it in 2 minutes.
My ISP uses VDSL2 over PPPoA and apart from the cheap router they supply no other router supports this, they changed my line to PPPoE from the MSAN and it connected.
