A Link Aggregation Question
Safar Safarov
I have 2811 Cisco ISR and two ISP links - one is 8 Mbps and the second is 4 Mbps. The question is - is it possible to aggregate link speed up to 12 Mbps?
if you use two default routes as described above you will have your load to be distributed over the two links
however by using PBR as per the example above better because you can control which type of traffic where to be sent as you have one link 4 and the other one is 8 M
if helpful Rate
Marwan ALshawi
Hi Safar
is this from one ISP or two diffrent ISPs i mean the links ?
in either way you could you routing load balancing by having two differnt default routes each point to a different ISP
this will do per session load balancing which is not 50 - 50 load balancing if you want it 100% you might need a separate device called loabalancer
however you can better utilize you both links by using PBR with IPSLA
for example you can send all http traffic over the 4 M link while ftp and other download traffic over the 8 M link and the tcan work as back up to teach other in the case one of them down
please refr to the following link for set by step example
https://supportforums.cisco.com/docs/DOC-8313
or if you want advanced way for load balancing you can try PfR
https://supportforums.cisco.com/docs/DOC-8353
if helpful Rate
actually I'm trying to raise a speed somehow. The links are from the same ISP. Is it possible?
if helpful Rate
Thanks for your help.
