A segment before this frame was lost
loyedokun2
What is causing a significant amount of the message (A segment before this frame was lost) in traffic on a MPLS routed WAN. Any help is appreciated. Running IBGP on MPLS backplane. Errors only noticeable on DS3 pportion of circuit. The following is DS3 output interface info from the router:
md254coreRtr01#show int serial1/0
Serial1/0 is up, line protocol is up
Hardware is DSXPNM Serial
Description: MDG Hub to vBNS Network
Internet address is 10.10.254.1/24
MTU 4470 bytes, BW 44210 Kbit, DLY 200 usec,
reliability 245/255, txload 24/255, rxload 12/255
Encapsulation PPP, LCP Open
Listen: CDPCP
Open: IPCP, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:01, output 00:00:07, output hang never
Last clearing of "show interface" counters 01:15:32 ********
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2188000 bits/sec, 644 packets/sec
5 minute output rate 4172000 bits/sec, 677 packets/sec
3207565 packets input, 1842773719 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 1 giants, 0 throttles
496338 input errors, 496337 CRC, 205118 frame, 30919 overrun, 0 ignored, 134896 abort *******
3097407 packets output, 2038896853 bytes, 0 underruns
0 carrier transitions
DSU mode 0, bandwidth 44210, real bandwidth 44210, scramble 0 md254coreRtr01#
htarra
Level 4
Level 4
I think you got this type of error :
"The segment before this frame was lost" Look for one of these frames in "Frame 78". Can you send me the sniff trace of that site in particular which you had problem with over the tunnel.
The following url will help you
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_tech_note09186a0080094b4e.shtml
I have attached 2 filtered wireshark capture filters showing the segment errors and others.
Thanks.
