A9K-8X100GE-L-SE stuck in reboot ASR9006
We've installed a new line card A9K-8X100GE-L-SE into our ASR9000 and it was up recently however upon a power cycle due to planned power outage the line card won't come back up on its own.  Im looking for some help on how to recover this device to boot time.  Our other line card pulls down firmware from the RSP just fine but this line card does not.  We've tried different slots as well.
RP/0/RSP0/CPU0:ios#show platform
Mon May 10 15:08:11.433 UTC
Node Type State Config State
0/RSP0/CPU0 A9K-RSP440-SE(Active) IOS XR RUN PWR,NSHUT,MON
0/0/CPU0 A9K-2x100GE-TR IOS XR RUN PWR,NSHUT,MON
0/6/CPU0 A9K-8X100GE-L-SE ROMMON PWR,NSHUT,MON
I've attempted a few times to set TFTP parameters on the line card by attaching to the console of the line card but not sure if my commands are right or not.  Can someone have a look at the boot up of the line card to see if you have any ideas on how I can rescue this thing?
Insyde Console Redirection Option ROM. Ver: 1.20
Console Redirection Index Device Port IRQ BaudRate Status
1 ISA 3F8 4 6400 OK
Use the <ESC><Ctrl><M> key sequence for <Ctrl><M>
Use the <ESC><Ctrl><H> key sequence for <Ctrl><H>
Use the <ESC><Ctrl><I> key sequence for <Ctrl><I>
Use the <ESC><Ctrl><J> key sequence for <Ctrl><J>
Use the <ESC><R><ESC><r><ESC><R> key sequence for <Ctrl><Alt><Del>
attachCon: To quit console session type 'detach'
attachCon: WARNING - Type only 'detach' in the shell. Do not combine other keys.
Current Baud 115200
Setting Baud to 115200
ooting ManagemeBooting Main Processor
Switching to line card CPU console
U3h3h3h
Starting ASR9k initialization ...
Reading both MB and DB cookie
Board Type:0x3d02aa
Non Powerglide & STLRD Settting i2c block 3
The base address of i2c_mux4to1 is at c8230800
zl init Octane cards
Missing Parameter SERVER_URL
System Bootstrap, Version 8.47 [ASR9K x86 ROMMON],
Copyright (c) 1994-2014 by Cisco Systems, Inc.
Compiled on Tue 12/18/2018 17:53:53.69
BOARD_TYPE : 0x3d02aa
Rommon : 8.47 (Primary)
IPU FPGA(PL) : 0.21.0 (Primary)
IPU INIT(HW.FPD) : 1.97.0
IPU FSBL(BOOT.BIN) : 1.103.0
IPU LINUX(IMAGE.FPD) : 1.103.0
MELDUN0 FPGA : 1.7.0
MELDUN1 FPGA : 1.7.0
DALLA FPGA : 1.9.0
CBC0 : Part 1=38.23, Part 2=38.23, Act Part=1
Product Number : A9K-8X100GE-L-SE
Slot Number : 8
Got EMT Mode as IOS-XR Boot
Since response is not received for os_type, switch to IOS-XR 32 bit
Got CBC OS type as IOS-XR 32 bit
Unexpected value, Got Boot Mode=65535
Booting IOS-XR (32 bit Classic XR) - Press Ctrl-c to stop
Checking OS type.
CBC OS type detected emt_mode 3 CBC OS type as 2
Set CBCOS type IOS-XR 32 bit, emt IOS-XR Boot to CBC
[PCIe Link] HOOPER_0 status: (up)0x3011 (dw)0x1011 <OK>
[PCIe Link] HOOPER_1 status: (up)0x3011 (dw)0x1011 <OK>
[PCIe Link] HOOPER_2 status: (up)0x3011 (dw)0x1011 <OK>
[PCIe Link] HOOPER_3 status: (up)0x3011 (dw)0x1011 <OK>
[PCIe Link] NIAN1_1 status: (up)0x3042 (dw)0x1042 <OK>
[PCIe Link] NIAN0_0 status: (up)0x7082 (dw)0x1082 <OK>
GigUndi Successfully retrieve emt mode as 3
Serial ATA Port 4 : SMART iSATA SHSLM32GEBCITHD02 Internal EFI ShellEFI Shell version 2.31 [4096.1]
Current running mode 1.1.2
Enter efi_start
Enter vx86rmon_efi_start
Entering vx86rmon_init
intializing Tomahawk LC RomMon
LC will boot from RP1/RSP1.
Board Type:0x3d02aa
DALLA FPGA : 1.9.0
CPU reset reason = 5 (CPU_RESET_POR)
Device mapping table
fs0 :HardDisk - Alias hd92e0a1 blk0
PciRoot(0x0)/Pci(0x1F,0x2)/Sata(0x4,0x0,0x0)/HD(1,MBR,0x00000000,0x20,0x2FB4FE0)
fs1 :HardDisk - Alias hd92e0a2 blk1
PciRoot(0x0)/Pci(0x1F,0x2)/Sata(0x4,0x0,0x0)/HD(2,MBR,0x00000000,0x2FB5000,0x98A800)
blk0 :HardDisk - Alias hd92e0a1 fs0
blk1 :HardDisk - Alias hd92e0a2 fs1
blk2 :HardDisk - Alias (null)
PciRoot(0x0)/Pci(0x1F,0x2)/Sata(0x4,0x0,0x0)/HD(3,MBR,0x00000000,0x393F800,0xC800)
blk3 :HardDisk - Alias (null)
PciRoot(0x0)/Pci(0x1F,0x2)/Sata(0x4,0x0,0x0)/HD(4,MBR,0x00000000,0x394C000,0x256800)
blk4 :BlockDevice - Alias (null)
hd92e0a1 :HardDisk - Alias fs0 blk0
hd92e0a2 :HardDisk - Alias fs1 blk1
disk0 :HardDisk - Alias hd92e0a1 fs0 blk0
disk0a :HardDisk - Alias hd92e0a2 fs1 blk1
map: Invalid argument - 'fs2:'
SPI Flash: NumonyxN25Q128
The value of autoc is 0xc09c2205
[NIANTIC] PCIE LINK UP
[Niantic] INTEL EOBC LINK UP
Marvel Hooper SGMII mode link is NOT UP! port 9
Get Active RSP: RSP0 Active
Marvel Hooper SGMII mode link is NOT UP! port 2
Marvel Hooper SGMII mode link is UP! port 2
Marvel Hooper SGMII mode link is NOT UP! port 3
[Niantic] HOOPER EOBC LINK UP
Sending Boot Image validation request.
HIT CTRL-C to abort
Interface link changed state to UP.
Interface link state up.
................Boot Image validation: Boot response retry
HIT CTRL-C to abort
HIT CTRL-C to abort
1 ISA 3F8 4 6400 OK
Exceeded 5 MBI Validation attempts. Doing hard reset
rommon 1 > Booting Management Processor
U3h3h3h
Board Type:0x3d02aa
DALLA FPGA : 1.9.0
Slot Number : 8
Checking OS type.
Enter efi_start
Board Type:0x3d02aa
DALLA FPGA : 1.9.0
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
It just continues to reboot here.  Below is the rommon settings output.
PS1=rommon ! >
BOARD_TYPE=3998378
CLUSTER_RACK_ID=0
RSP_TYPE=0
IP_SUBNET_MASK=255.255.0.0
DEFAULT_GATEWAY=127.0.1.4
TFTP_SERVER=127.0.1.4
TFTP_FILE=/disk0/asr9k-os-mbi-6.4.2/lc/mbiasr9k-lc.vm
BSI=0
?=1
IP_ADDRESS=127.0.1.0
And when I run just 'boot'
It comes up with this and just keeps retrying.
rommon 2 > boot
Beginning External Image validation boot:
HIT CTRL-C to abort
0 Replies 0
