AAA Authentication Issue
shawkatalvi
Hi Guys,
I have config for AAA:
enable secret 5 $ $xxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxx
username admin password 7 xxxxxxxxxxxxxx
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication login console line
aaa authentication enable default group tacacs+ enable
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting commands 15 default stop-only group tacacs+
aaa session-id common
line con 0
privilege level 15
password 7 xxxxxxxxxxxxxxxxxxxxxx
login authentication console
line vty 0 4
exec-timeout 120 0
password 7 xxxxxxxxxxxxxxxxxxxxxxxx
Problem is when the Router looses its connection to TACACS+ server, it can't authenticate user with the local authentication. For backup I would like to get authenticated into the router should the TACACS+ server is unreachable.
Thanks.
Giuseppe Larosa
Hello Shawkat,
to have local username password fallback you should use
aaa authentication login default group tacacs+ local
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for your quick reply. If I use the following config:
aaa new-model
aaa authentication login REMOTE group tacacs+ local-case
aaa authentication fail-message #
Local authentication failed.
aaa authentication password-prompt "Enter local password:"
aaa authentication username-prompt "Enter local username:"
user a secret b!
line con 0
login authentication REMOTE
line vty 0 4
Would I be able to access the router with privilege level 15 and if the TACACS+ server fails, it would allow me to authenticate locally?
Hello Shawkat,
you will be able to login with local account only when the TACACS+ is unreachable.
When TACACS+ is reachable you need to use an account defined on it.
see the list
as an ordered list of methods where second method is used only if the first one doesn't get a timely answer.
if you perform lab tests you will see that as soon as the server is reachable again the local account cannot perform commands on the device.
Hope to help
Giuseppe
Thanks Giustar for your feedback.
I used this config:
username admin privilege 15 secret xxxxxxxxxxxx
aaa new-model
aaa authentication login default group tacacs+ local-case
line con 0
line vty 0 4
when TACACS+ was unreachable I could login into the router via console, but via line vty 0 4 it only let me in to the read only mode(privilege level 1). As soon as I typed "en" it said "error in authentciation". I expected Line vty would work the same way console 0 worked. Any ideas?
