About Frame Relay
philipsyao
I'm using a 6509 and need to enable frame-relay switching on the platform. However, after I set up the interface configuration, I canot find the "frame-relay route" command. I did enable "frame-relay switching" in the global configuration mode.
Thanks for your comment.
Are you using a flexwan module in the switch?
the corresponding information:
Adapter: "WS-X6182-2PA 2 port adapter FlexWAN Rev. 1.5"
Line Card: "Channelized DS3 - single wide, one port" PA-MC-T3
IOS version: 12.2(18)SXD2
My configuration:
controller T3 7/0/0
t1 1 channel-group 0 timeslots 1-24
t1 2 channel-group 0 timeslots 1-24
t1 3 channel-group 0 timeslots 1-24
t1 4 channel-group 0 timeslots 1-24
t1 5 channel-group 0 timeslots 1-24
t1 6 channel-group 0 timeslots 1-24
t1 28 channel-group 0 timeslots 1-24
interface Serial7/0/0/1:0
no ip address
no ip unreachables
encapsulation frame-relay IETF
no fair-queue
no arp frame-relay
frame-relay interface-dlci 34
What I'm planning to do is aggregate all the user data and management data from all teh sites through T1, terminate the user data(DLCI 34) and get the Authentication and get the ip address locally. Then switch the management data (DLCI 33) to another T1 (T1 28 in this case) which will be connected to the DSLAM Gateway for management.
purohit_810
Level 5
Level 5
Can you give configuration and IOS name .... so we can conclude?
Reply ASAP.
Dharmesh Purohit
did not try this on a FlexWAN, but a guess: Is there an "Router(config)#connect" command? It might do the trick. For details in "normal routers" have a look at
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080080fdc.html#wp1055712
Regards, Martin
