02-06-2012 12:28 PM - last edited on 06-06-2022 12:23 AM by Translator
I need to adapt a Cisco Catalyst switch configuration into a new ASR9000 router and I do not know how to configure trunks and access ports on an ASR9K router.
This is the configuration of the catalyst switch I want to replace.
interface GigabitEthernet1/0/1
description Access-Port -> SERVER
switchport access vlan 5
spanning-tree portfast
interface GigabitEthernet1/0/2
description Trunk-Port -> DISTRIBUTION SWITCH
switchport trunk allowed vlan 5,6,7
switchport mode trunk
I think it should be someting like this:
interface GigabitEthernet0/0/0/0
interface GigabitEthernet0/0/0/0.5 l2transport
interface GigabitEthernet0/0/0/1
interface GigabitEthernet0/0/0/1.5 l2transport
encapsulation dot1q 5
interface GigabitEthernet0/0/0/1.6 l2transport
encapsulation dot1q 6
interface GigabitEthernet0/0/0/1.7 l2transport
encapsulation dot1q 7
Am I right? Or do I need to use the command
rewrite ingress tag pop 1 symmetric
on any of the interfaces o subinterfaces? Do I have to configure the command
encapsulation dot1q untagged
on the GigabitEthernet0/0/0/0.5 subinterface?
Please, help!!
Thank you in advance.
Solved! Go to Solution.
02-10-2012 02:39 AM - last edited on 06-06-2022 12:25 AM by Translator
You’d need to create separate l2vpn bridge domains per different customers and use tag rewrite on trunk subif.
! Trunk port
! Access ports
description Access-Port vlan 5
l2transport
interface GigabitEthernet0/0/0/2
description Access-Port vlan 6
l2transport
interface GigabitEthernet0/0/0/3
description Access-Port vlan 7
l2transport
l2vpn
bridge group VLANs
bridge-domain vlan5
bridge-domain vlan6
bridge-domain vlan7
/A
02-10-2012 11:43 AM
If you configure a subinterface, you’d need to define an encapsulation.
As I understood that is access port with untagged frames, hence we don’t need subinterfaces and we should use a main interface as l2transport.
/A
! Trunk port
! Access ports
l2transport
l2transport
l2transport
l2vpn
bridge group VLANs
bridge-domain vlan5
bridge-domain vlan6
bridge-domain vlan7
/A
02-10-2012 03:26 AM - last edited on 06-06-2022 12:28 AM by Translator
Thanks for your reply,
If I configure:
do you think it would work?
Thanks in advance
02-10-2012 11:43 AM
/A
01-24-2013 01:56 AM - last edited on 06-06-2022 12:41 AM by Translator
I tryed the configration but I saw not runing. Configurations are below.
interface TenGigE0/1/0/0.611 l2transport
encapsulation dot1q 611
interface TenGigE0/1/0/0.612 l2transport
encapsulation dot1q 612
l2vpn
bridge group kzy2kyl
bridge-domain kzykd2kylmlt
12-13-2018 12:56 AM - last edited on 06-06-2022 12:41 AM by Translator
Hi tried the following configuration:
interface bvi611
interface bvi612
l2vpn
bridge-domain 611
routed interface bvi611
bridge-domain 612
routed interface bvi612
06-15-2023 08:13 AM
What about the subnet for the Access Ports? Where is that configured?
02-11-2012 02:08 AM
