Access citrix server through 827
basheerpt
Can anybody advise me how to allow outside request to my internal citrix webinterface through an 827 router? all other traffic from outside should be blocked too.
also, how to allow only single computer allow access the internet from my given LAN?
Following is the full configuration. I am a novice in cisco so please bear with me, i appreciate if you point me any errors in the configs.
______________________________________
Current configuration : 1755 bytes
version 12.3
no service pad
hostname MYROUTER
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
ip subnet-zero
no voice hpi capture buffer
no voice hpi capture destination
interface Ethernet0
ip address 192.168.100.27 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
dsl firmware secondary
interface ATM0.2 point-to-point
pvc 0/35
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxx
ppp chap password 0 xxxxxxxxxxx
ppp pap sent-username xxxxx password 0 xxxx
ppp ipcp dns request
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
access-list 1 permit 192.168.100.0 0.0.0.255
voice-port 1
voice-port 2
voice-port 3
voice-port 4
line con 0
transport preferred all
transport output all
stopbits 1
line vty 0 4
login
transport input all
scheduler max-task-time 5000
end
MYROUTER#
spremkumar
Level 9
Level 9
If you want your remote users to access your citrix server which is kept inside your local lan then you need to do proper one to one static mapping(NAT) with the public ip address which can be accessed from the outside world.
If you wish you can have port based mapping(NAT) which can be accessed from the remote users.
ip nat inside source static tcp 192.168.10.1 25 171.69.232.209 25
here the inside host 192.x.x.x has been natted with 171.x.x.x so your remote users will be accessing 171.x.x.x ip in order to access the internal server.
but i m not seeing any static ip being used in your config to achieve this.
for allowing a single pc alone to access interet i would suggest to modify the access-list permitting the ip of the pc which is required to access the internet.
regds
Thanks a lot.
Yes, i am not using static IP for internet this time. so, is it correct to use like the following?
ip nat inside source static tcp 192.168.10.1 25 dialer1 25
Besides this, i found in a forum that it should use in the dialer as follows:
IP Access group xxx in
If you dont mind, please help me to write the exact configuration
Best regards
Hi Basheer
Though i havent tried exprimenting ever with interface followed by the port number i dont think that will work or even allow the command to be keyed in.
also the one i posted is just a sample dealing with SMTP connection citrix ICA normally uses 1494.
so you need to open both UDP/TCP ports 1494 accordingly.
You can block the access by either ways by configuring alone the ip address which is attached to the nat overload statement you will be able to access internet only with that ip.
access-list 1 permit 192.168.100.x
where 192.168.100.x is the ip from which you want to have internet access
regds
Thanks again.
I did try as follows but it didnt open my internal webserver page. here is the config i changed:
ip nat inside source static tcp 192.168.100.8 8081 interface Dialer1 80
ip nat inside source static tcp 192.168.100.8 443 interface Dialer1 443
ip classless
ip http server
access-list 1 permit 192.168.100.8
access-list 1 permit 192.168.100.128
Is the configuration correct? when i enter my external IP in the browser, i dont get redirected to the internal webservers page, instead i get page cannot be displayed.
Thanks for any help
