01-21-2008 01:23 AM - edited 03-03-2019 08:20 PM
I am using a PA-2FE-FX port on 7507MX router.When the fibre cable is connected ,then the line protocol is down.But when the speed is 10Mb, the line protocol is up irrespective of cable connected or not.But ping is not working when cable is present and line protocol is up. The IOS is 12.0(30)S1. The VIP is VIP4-50.
Why the interface is not coming up for 100Mb.?
Please help in troublshooting the issue.
Thank you,
Peter
01-21-2008 01:28 AM
hi,
What is @ other end?Plz check the speed and duplex settings @ both ends.If possible configure these settings manually.
HTH,
regards,
shri :)
01-21-2008 01:28 AM
You might have tried it already, but what happens when you connect a single fibre from TX to RX on the port? Does the interface come up then?
01-21-2008 01:36 AM
we are trying that now.
The other end is ethernet convertor and PC connected to this convertor ,checked all speed and duplex combinations. All did manually.
Thank you,
Peter
01-21-2008 02:05 AM
Will the IOS we are using support PA-2FE-FX ?
Is there any special configuration we have to do ? or is there any comaptibility issues with this card ?
Thank you,
Peter
