Access list confusion
crmljc1976
Please can someone help. all traffic seems to be blocked when using this config. It seems that outbound traffic is blocked or that all inbound traffic is blocked. Im not really sure. Can someone tell me why?
Router#sh run
Building configuration...
Current configuration : 2627 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1xxxxxxxxxx!
no aaa new-model
dot11 syslog
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip name-server 194.x.x.68
ip name-server 194.x.x.69
archive
log config
hidekeys
interface ATM0
no ip address
atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode itu-dmt
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
ip access-group 101 in
encapsulation ppp
ip tcp adjust-mss 1380
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxxxxxx
ppp chap password 0 xxxxxxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.0.5.0 255.255.255.0 192.168.0.2
no ip http server
no ip http secure-server
ip dns server
ip nat inside source static tcp 192.168.0.5 2000 interface Dialer0 2000
ip nat inside source static udp 192.168.0.5 2000 interface Dialer0 2000
ip nat inside source static tcp 192.168.0.5 2002 interface Dialer0 2002
ip nat inside source static udp 192.168.0.5 2002 interface Dialer0 2002
ip nat inside source static tcp 192.168.0.5 2003 interface Dialer0 2003
ip nat inside source static udp 192.168.0.5 2003 interface Dialer0 2003
ip nat inside source static tcp 192.168.0.5 2006 interface Dialer0 2006
ip nat inside source static udp 192.168.0.5 2006 interface Dialer0 2006
ip nat inside source static tcp 192.168.0.5 3001 interface Dialer0 3001
ip nat inside source static udp 192.168.0.5 3001 interface Dialer0 3001
ip nat inside source static tcp 192.168.0.2 3389 interface Dialer0 3389
ip nat inside source static tcp 192.168.0.5 5900 interface Dialer0 5900
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 101 permit tcp any any eq 5900
access-list 101 permit tcp any 192.168.0.0 0.0.0.255 established
control-plane
line con 0
no modem enable
line aux 0
line vty 0
password xxxxxxx
login
line vty 1 4
login
scheduler max-task-time 5000
end
8 Replies 8
lgijssel
Level 9
Level 9
This looks like an internet connection.
The acl 101 will block aal udp, including dns traffic. This might be a problem.
Otherwise, try the config without acl 101 and verify that it works. You can secure up things from there.
regards,
Leo
crmljc1976
yes works without the list. Will all inbound traffic from internet be denied apart from the nat inside source rules ive created? And will those rules still work?
gacross
Inbound there will be allowed only packets with destination port of 5900 and anything with the ack bit turn on in the TCP header. (outbound response packets.) You should add the ports and ip addresses your have staticly nat'd.
eg: access-list 101 permit tcp any any eq 3389
access-list 101 permit udp any any eq 3001
don't forget permit udp any eq domain any
etc
Without an acl on the outside the router itself could be subject to DoS or hacking. I would at least put an ACL on the vty to prevent outside from accessing the router.
ok, but when i add ip access-group in to the dialer0 interface all traffic is blocked, so what is the point?
with the above access-list u r allowing any traffic with the source of any to port 5900
and with the second line u r allowing traffic with any source to 192.168.0.0
the rest of this traffic is denied as the access-list will have a implicit deny statement at the end,due to this u r not able to access anything except the entries permitted in the acl.
Mahmood
and I don't need to use the access group command on on interface?
no that doesnt work neither, Does anyone know how to resolve this issue????
You have 2 issues with the access list. First is that you have only done a single port even though you have defined multiple nat entries. If you want those nat entries to ever work you need to put in a corresponding access list.
You second issue is much harder. The access list is done before the nat so your destination address has not been translated to the 192.169.x.x addresses yet so this line in effect blocks everything.
You really don't need a access list when you run nat other than maybe to protect the router itself.
The main difference is that a access drops the traffic because you told it to. Nat will cause a drop because it does not know who to send the packet to if there is no translation in the table. Access list is better but you will get the same results.
