Access list help
The_guroo_2
Level 2
Level 2
gues if i want to block two network
192.168.1.0/24 and 192.168.3.0/24
what will b ethe access list for that keeping in mind that i want to get the job done in one line (access-list staement) and can someone please tell me how you did that....thanks
Gerald Vogt
Level 3
Level 3
access-list 1 deny 192.168.1.0 0.0.2.255
Matthew Warrick
access-list 1 deny 192.168.1.0 0.0.3.255
edit: I type slow
Giuseppe Larosa
Hello Khan,
you need to think at the binary of the base subnet ip address
192.168.1.0/24
192.168.3.0/24
and look for waht they have in common:
they have in common the first two bytes and the 1 bit set in the least meaning bit of the third byte
so
192.168.1.0
the wildcard mask in ACL can contain multiple transitions 0 to 1 and 1 to 0.
0.0.2.255
the third byte is in binary:
00000010 : first 6 bits are 0 must match the last bit must be 1 must match the bit that makes the difference between 1 and 3 can be set to any value
so it is:
access-list 12 deny 192.168.1.0 0.0.2.255
notice that
access-list 12 deny 192.168.1.0 0.0.3.255
is wrong because is matching
192.168.0.0/24
192.168.1.0/24
192.168.2.0/24
192.168.3.0/24
that is not the same
Hope to help
Giuseppe
