Access list
The_guroo_2
Level 7
Level 7
i have a genral question abt wild card mask.....like if we wanna allow or deny a whole class we write 210.54.8.0 0.0.0.255 but some time we use 210.54.8.0 0.0.0.0........like both thing r same so in which scenario we will use all o's and in which scenarios we will use 255.........at he last....thanks in advance
royalblues
Level 11
Level 11
Hi shahryar
The theory behind the access-list wild cards mask is : 0 is considered to be exact match and
1 is considered to be a wild card or dont care
so in the ablove example 210.54.8.0 0.0.0.255 the last octet is all 1s and hence represent dont care bits. i.e match the first 3 octets exactly while ignoring the 4th octet
but if you have 210.54.8.0 0.0.0.0 configured,it is asking it to match all the 4 octets exactly which would basically mean to match a single host.
(actually cisco converts the mask 0.0.0.0 as host and 255.255.255.255 as any)
Narayan
