Accessing inside Server from two ISP at same time
tanveer2005
Can someone tell me, how to access insdie serve from two public IP for 2 ISPs. Static NAT or PBR.
Please se the attached
My goel is to access inside Server from outside with two public IP from 2 ISPs at same time. by static NAT or PBR.
Please help me.
This is runn conf.
interface FastEthernet0/0.1
encapsulation dot1Q 9———–LAN
ip address 10.10.5.70 255.255.255.0
ip nat inside
interface FastEthernet0/0.3
encapsulation dot1Q 3———- ISP-1
ip address 82.128.161.50 255.255.255.224
ip nat outside
interface FastEthernet0/0.4
encapsulation dot1Q 4————–ISP-2
ip address 77.192.187.250 255.255.255.248
ip nat outside
ip nat inside source static 10.10.5.60 82.128.161.51 route-map isp1
ip nat inside source static 10.10.5.60 77.192.187.251 route-map isp2
ip classless
ip route 0.0.0.0 0.0.0.0 77.192.187.254
ip route 0.0.0.0 0.0.0.0 82.128.161.33 20
no ip http server
route-map isp2 permit 10
match interface FastEthernet0/0.4
route-map isp1 permit 10
match interface FastEthernet0/0.3
5 Replies 5
tanveer2005
No body give or explain , i think, It need some Experit.
mrdogantr
Add commands below in your config.
access-list 10 permit 10.10.5.0 0.0.0.255
access-list 20 permit 10.10.5.0 0.0.0.255
ip nat inside source list 10 interface FastEthernet0/0.3 overload
ip nat inside source list 20 interface FastEthernet0/0.4 overload
hth
Muammer
hth
Muammer
You will find that such commands, make NAT fail.
the wan router have two different interface for
two different isp
just configure two different public ip on two interface invidually and pint default route from those interfaces
nothing to do with route-map
It is working Fine, but you need two IP for LAN , and no need Default route, If some one have other solution for only ony IP for LAN server , please Explain.
Router#sh runn
Building configuration...
Current configuration : 1937 bytes
version 12.3
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$HS45408$iutGDSO7r73434mFH.d0bgjOZ/
enable password 7 1218011A135B05580C252720245413D32
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface Loopback0
ip address 192.168.150.1 255.255.255.252
ip nat outside
ip policy route-map PBR-LOOP
interface ATM0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
no ip address
speed auto
full-duplex
encapsulation dot1Q 9---------------------LAN
ip nat inside
ip policy route-map PBR-LAN
interface FastEthernet0/0.3 -------------- ISP1
ip nat outside
interface FastEthernet0/0.4-------------- ISP2
ip nat outside
ip nat inside source static 10.10.5.61 82.128.161.51
ip classless
no ip http server
ip access-list extended STATIC-NAT-ISP1
permit ip host 82.128.161.51 any
ip access-list extended STATIC-NAT-ISP2
permit ip host 77.192.187.251 any
ip access-list extended STATIC-NAT-SERVICES
permit ip host 10.10.5.60 any----------------- SERVER LAN IP 1
permit ip host 10.10.5.61 any------------------SERVER LNA IP 2
route-map PBR-LAN permit 10
match ip address STATIC-NAT-SERVICES
set ip next-hop 192.168.150.2
route-map PBR-LOOP permit 10
match ip address STATIC-NAT-ISP1
set ip next-hop 82.128.161.33
route-map PBR-LOOP permit 20
match ip address STATIC-NAT-ISP2
set ip next-hop 77.192.187.254
snmp-server community public RO
snmp-server enable traps tty
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
password 7 14161606050A7E232B24GFY34JHF373C2C1453
login
end
Router#
