Accessing Routers from the Access Server
newnetman
Hi All,
Can anyone please come to my aid as to why three of my ten routers refuses my admission from the AS?.
Even after clearing the lines. Here is the example output from one of the Routers.
Access-Server#clea lin 6
[confirm]
[OK]
Access-Server#r6
Trying r6 (201.201.1.1, 2006)... Open
Hence the router remains in the "open state" indefinitely.
Your urgent help shall be appreciated.
6 Replies 6
Calin C.
Level 5
Level 5
Hi!
Cables used for connections (AS to routers) are the right ones?
Can you issue a "sh line" and give the output here?
You have the same behavior on all devices or only on some?
What AS you use? What cards?
Thanks!
Cheers,
Calin
Hi calin,
Many thanks for your prompt response.
Responses to your Questions:
cables used are right (Rolled cables)
Do not have the same behavior on all devices only o three out of ten
The AS is AS2511-RJ
Here is the sh line output
Access-Server#sl
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 36 0 0/0 -
* 1 TTY 9600/9600 - - - - - 2 1 0/0 -
* 2 TTY 9600/9600 - - - - - 2 0 0/0 -
* 3 TTY 9600/9600 - - - - - 2 1 0/0 -
* 4 TTY 9600/9600 - - - - - 5 0 0/0 -
* 5 TTY 9600/9600 - - - - - 5 0 0/0 -
* 6 TTY 9600/9600 - - - - - 7 1 0/0 -
* 7 TTY 9600/9600 - - - - - 2 0 0/0 -
* 8 TTY 9600/9600 - - - - - 7 0 0/0 -
9 TTY 9600/9600 - - - - - 3 0 0/0 -
* 10 TTY 9600/9600 - - - - - 1 0 0/0 -
11 TTY 9600/9600 - - - - - 0 0 0/0 -
12 TTY 9600/9600 - - - - - 0 0 0/0 -
13 TTY 9600/9600 - - - - - 0 0 0/0 -
14 TTY 9600/9600 - - - - - 0 0 0/0 -
15 TTY 9600/9600 - - - - - 0 0 0/0 -
16 TTY 9600/9600 - - - - - 0 0 0/0 -
17 AUX 9600/9600 - - - - - 0 0 0/0 -
18 VTY - - - - - 0 0 0/0 -
19 VTY - - - - - 0 0 0/0 -
20 VTY - - - - - 0 0 0/0 -
21 VTY - - - - - 0 0 0/0 -
--More--
Many thanks for your help.
regards
From what I'm seeing here is that your lines are in use (the * in front is there when you have an open connection on the line).
Do a "clear line tty 6" and check if the * in front disappear and please tell me.
Cheers,
Calin
Hi Calin,
Thanks again. Upon carrying out your instruction as shown bellow, i realized the resulted in the former behaviour.
Access-Server#clea lin tty 6
[confirm]
[OK]
Access-Server#r6
Hence remain there infinitely, but i tried it the same router on a different port on the Access-server and it works, should i then suspect that the problem is with port6 of the AS?.
Your further help shall be appreciated, hence what is the difference between Sh lin 6 and sh line tty 6?
regards
Try to compare the output of "sh line 6" with one of the working ones, see if there is something wrong there.
You can try to switch the cable from line 6 with the one that you can see that it is working. Can you reach the same router (former connected to cable 6) via new connection? If yes than it's a problem with line 6 or cable connected to it. If not...check your router...maybe the console port has a problem.
Btw, there is no difference between sh line 6 and sh line tty 6 , but I like to specify what kind of line is there :)
Good luck!
Cheers,
Calin
Giuseppe Larosa
first of all on the access server you need to verify that the line associated with R6 is not already in use or appended in that case you need to free it with clear line .
Then, all the checks already suggested
Hope to help
Giuseppe
