Accesslist
sham_chennala
I want to block telnet access in our internet router for that iwant to configure a accesslist in that router what is the command i want use for implimenting this.
access-list 101 deny ip <source add><source wild mask> <destination add><desti wild mask> eq 23
is this command right if there is any mistake plese inform me.
Thanks & Regards
Sham
Nagendra Kumar Nainar
If you want to block anyone connecting via telnet to your router, You can simply use a standard ACL and apply the same under line vty 0 -4. This will block telnet from specified source addresses. EX below,
access-list 1 deny any
line vty 0 4
access-class 1 in
If the ultimate device ( the one where you want users not to be connected via telnet) is within your network. Your command is right.
HTH,
Nagendra
Danilo Dy
For example, you only allow 192.168.1.1 telnet access to your router and block all other IPs
ip access-list standard VTY
permit 192.168.1.1
line vty 0 4
access-class VTY in
exec-timeout 15 0
transport input telnet
end
Dandy
Goutam Sanyal
Level 4
Level 4
As per Cisco:
To restrict incoming and outgoing connections between a particular vty (into a Cisco device) and the addresses in an access list, use the access-class command in line configuration mode. To remove access restrictions, use the no form of this command.
*Simply u can configute a Standerd ACL and enable it to line conf mode
#conf t
#line vty 0 4
#access-class access-list-number {in | out}
Goutam
***Please use rateing sys***
