ACL counters issue
Hi!
I have 2911 router with 15.0 IOS + security + data. The problem is in ACL hit logging. Even if i applied statement "permit ip any any log" on the interface, counters would not match anything.
Did you search for the possibiltiy of a bug?
I have involved to a problem with an Access-list that denied all and was solved with a new IOS
https://supportforums.cisco.com/message/3591511#3591511
Hope that helps,
Vasilis
6 Replies 6
Edison Ortiz
Can you provide configs and example of exactly what you are seeing?
Yes, here you are:
interface GigabitEthernet0/0
ip address 172.16.1.1 255.255.255.252
ip access-group test_acl in
ip flow ingress
ip flow egress
duplex auto
speed auto
ip access-list extended test_acl
i am seeing:
#show interfaces gigabitEthernet 0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is c471.fec5.89f8 (bia c471.fec5.89f8)
  Internet address is 172.16.1.1/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:10, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 35
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 186000 bits/sec, 10 packets/sec
  5 minute output rate 27000 bits/sec, 14 packets/sec
     418641389 packets input, 3158351856 bytes, 0 no buffer
     Received 69630 broadcasts (0 IP multicasts)
     0 watchdog, 66277 multicast, 0 pause input
     439197818 packets output, 803260124 bytes, 0 underruns
     0 unknown protocol drops
     2 lost carrier, 0 no carrier, 0 pause output
#sh ip access-lists
Standard IP access list RADMIN
    10 permit 172.16.2.0, wildcard bits 0.0.0.255 (12 matches)
Extended IP access list test_acl
    10 permit ip any any log
Unable to duplicate:
System image file is "flash0:c2900-universalk9-mz.SPA.151-1.T.bin"
ip access-list extended acl-in
ip address 100.1.13.200 255.255.255.0
ip access-group acl-in in
duplex auto
speed auto
Router#ping 100.1.13.200
Sending 5, 100-byte ICMP Echos to 100.1.13.200, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Router#
%SEC-6-IPACCESSLOGDP: list acl-in permitted icmp 100.1.13.250 -> 100.1.13.200 (0/0), 1 packet
Extended IP access list acl-in
    10 permit ip any any log (9 matches)
Hope that helps,
Vasilis
I am suspecting IP CEF enabled globally
Hi Vyacheslav,
IP CEF is activated globally by default indeed, but on ISR and ISR G2 routers, CEF is purely software-based. Counters on ACLs are not incremented if they are processed in hardware, which should not be the case here.
Best regards,
Peter
